flathead 8 running on 4? - Ford Truck Enthusiasts Forums
Old 07-06-2014, 02:01 PM
dangson dangson is offline
dangson is starting off with a positive reputation.
I got my old 52 f1 running and it has low power. Seems to vibrate like the new 8's that run on 4 to save fuel. Doesn't backfire. But sluggish.
Old 07-06-2014, 09:47 PM
GB SISSON's Avatar
GB SISSON GB SISSON is offline
GB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant future
I think you'll find that 2 on each side are dead. This is because one circuit in the carb is clogged. At least that was it when mine started running on 4.
Old 07-06-2014, 11:10 PM
I have 4 wet plugs and 4 dry. Changed plugs, wires and cap. No change.
Old 07-06-2014, 11:26 PM
GB SISSON's Avatar
See if they are front and rear cyls on one side and 2 middle ones on the other side. The wet plugs were getting fuel, the dry ones, not. I kept thinking ignition at first, but it was carburetion. Follow the runners in your intake manifold. They tell the story.
Old 07-06-2014, 11:37 PM
We will take a look. Thanks.
Starts but wont Run grantkat 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 46 09-07-2015 12:33 PM
Day-Time Running Lights Tugnut 1997 - 2003 F150 2 04-04-2015 01:26 PM
2003 5.4 runs rough on start up and short runs, not always mschue42 1999 to 2016 Super Duty 0 02-17-2015 08:18 PM
Running boards and box needed ricbeatenhead 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 08-07-2014 11:42 AM
tps signal out to pcm Uncle JimBod 1987 - 1996 F150 & Larger F-Series Trucks 10 07-04-2014 03:34 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
