300 I6 or a flathead 8 in a 1960 4x4
I just bought a 1960 F100 4x4 and will be doing a rebuild. The truck already has a few modifications and it will not be a restore project but needs to be a daily driver. I am torn between the idea of putting a flathead 8 in the truck or a straight 300 six. I know the benefits and drawbacks of the six already but love the look of the less familiar (at least to me) flathead. The truck needs to be a daily driver on highways with normal speeds of 70mph for an hour travel time both to and from work. I will be installing new gearing and upgrade transmission for either choice. All upgrades will also take into account gas mileage for economics. Any input would be helpful. Both engines will also be upgraded and modified as necessary.
The reason we love flatheads is because they belong in certain vehicles. I'm just putting the finishing touches on a '47 two ton with a used one in it. It will run at about 45 mph max, and maybe get used 10 times a year...... As said, they are very expensive to build and don't have the hp and torque you'd want in a 4x4 DD. The flathead is prone to cracks and all in all can be a problematic power plant for daily use. I daily drove a 59 ab flathead for 10 years back in the 80s and 90s. This was in a 38 tonner, where it belonged. Not sure why you wouldn't run a 272 or 292 Y block. Since you suggested this as well, I give a hearty vote for the 300 six. It's a very heavy duty truck engine with seven main bearings and excellent torque characteristics. It will move your truck down the road very nicely and will look more the part under the hood. Engines have steadily improved over the years, and you should take advantage of this. 300 sixes show up on CL and a nice 4 speed to go along with it. When they say "they just don't make 'em like they used to" ..... It's a good thing when referring to engines.
If you want a six with good mileage and plenty of pulling power go to youtube and type in 59 f350 with cummins 6at. Then you'll have it all! Much smaller and less common than the 6bt in the dodges. Gotta say Spur is right on with the 302 for a lot of reasons. Surprised he didn't suggest a 223 !
on
My vote goes to a Y block 292 or the 223 inline 6. Put a T98 behind it like Henry wanted it. Easy beans straight forward bolt in. Easy to work on, etc.. Get your highway speed with taller tires and enjoy. And for the record, I am bias! If you plan on spending 2 hours driving this truck every day, save some money for the interior. Sound deadening, a comfy seat, new door seals, etc.
Really depends on what you want for a finished product. The 223 will be a no brainer to install, the 300 I can imagine new mounts and lots of other fabrication tasks. The 300 will have considerably more power for pulling trailer or hauling weight up a grade. As a DD the 223 will be more economical. The choice is yours. They are both good old ford engines.
blueovalfan1
186
05-27-2017 12:16 PM
Dustin_86
Ford vs The Competition
01-19-2005 09:16 PM
MatthewC
10-12-2004 07:37 AM
