E brake won't hold in reverse - Page 3 - Ford Truck Enthusiasts Forums
  #31
Old 07-10-2014, 12:11 AM
Spktyr Spktyr is offline
Spktyr is gaining momentum as a positive member of FTE.Spktyr is gaining momentum as a positive member of FTE.
It should be mentioned that on our trucks (as with many cars) reverse is a very deep gear. On the E4OD transmission, reverse is 2.16:1, which means that it's got only slightly less torque to the ground than it does in first. Add in the fact that most drum brakes are less effective going against reverse than forward and the fact that you're inputting 450lb/ft into the system (way more than the gas truck can do) and you're looking at your explanation, assuming you have the typical worn (not worn out, just worn) drum brake assembly.
Further, FMVSS 105 subsection 5.2.1 does not apply to trucks. Trucks are not passenger cars; the reg says passenger cars and school buses only. There is also the fact that FMVSS in this case only applies to the vehicles as they are when new, not when they're almost 20 years old.
All that said, I would check to make sure your brakes are *properly* adjusted - both the parking brake cables and the actual brake shoe adjusters out back. The truck's parking brake should hold at idle (defined as ~700rpm) on most any angle you are likely to encounter. If you press the throttle, all bets are off - but it *should* be holding at idle. The star wheel automatic adjusters do sometimes need help, though.
  #32
Old 07-10-2014, 11:52 AM
Nothing Special's Avatar
Nothing Special Nothing Special is offline
Nothing Special has a great reputation on FTE.Nothing Special has a great reputation on FTE.Nothing Special has a great reputation on FTE.Nothing Special has a great reputation on FTE.Nothing Special has a great reputation on FTE.
I did have an auto trans parked on a hill once where I couldn't get it out of park due to the load on the pawl (I had not used the e.brake). we got a few people behind the truck and pushed it up hill to take the load off the pawl so someone could shift it.
  #33
Old 07-10-2014, 12:53 PM
cbakker's Avatar
cbakker cbakker is offline
cbakker is starting off with a positive reputation.
Quote:
"should hold"
Here in flat farmland country, the "e-brake" is rarely used, even on manual trans vehicles. 90% of the trucks I have used the PARKING BRAKE on, had siezed up cables from minimal to no use, so they wouldn't fully release when desired.
My local mechanic freaks out when he hears the term e-brake, or emergency brake, because this is absolutely not what its intended purpose is.
Quote:
Originally Posted by danr1 View Post
Yes should work in forward and reverse but it is common to loose effective hold in reverse, if shoes are worn out of adjustment by just a little bit hold suffers. If drums are at or near wear limit its even worse, best hold is when shoes and drums are new very little to no wear on them, cam action previously mentioned has all to do with it big shoe little shoe.
If rear brakes are in decent enough shape and properly adjusted it should hold "no load" at minimum.
When they are worn out, I have seen a difference in the 3" shoes vs. the 2.5" ones. I don't know if it is only the HD models that have the 3'' shoes, but even when mine are worn/ out of adjustment, they will still hold my truck on a <5% grade forward and reverse.
I like the Yahoo answers explanation, because this describes exactly how the friction is applied directionally.
When drums and shoes are both replaced, and properly adjusted, they can hold a lot more than a static load, but once they start to wear, forget about anything but a static load in reverse.
  #34
Old 07-11-2014, 10:20 AM
joey2fords's Avatar
joey2fords joey2fords is offline
joey2fords is gaining momentum as a positive member of FTE.joey2fords is gaining momentum as a positive member of FTE.
My local mechanic freaks out when he hears the term e-brake, or emergency brake, because this is absolutely not what its intended purpose is...
he can freak out to his hearts content, but in the event that ones brake pedal sinks to the floor with no stopping effort, one is much more likely to reach for the parking/emergency brake than the windshield wiper switch.
  #35
Old 07-11-2014, 03:58 PM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is offline
Diesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud of
Agreed. It is and EMERGENCY BRAKE, in case of an EMERGENCY when the hydraulic brakes go out
  #36
Old 07-11-2014, 05:53 PM
tjc transport's Avatar
tjc transport tjc transport is offline
i ain't rite
tjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputation
when a brake line goes, i reach for the shifter and downshift.
i have never had a working parking brake i could trust on any vehicle i have ever owned, except for the trans mounted driveshaft brake on my 88 F-superduty.
  #37
Old 07-11-2014, 08:22 PM
weskan weskan is offline
weskan is starting off with a positive reputation.
The park brake should hold forward and reverse. If it doesn't hold reverse, then it just needs to be adjusted.
I adjust mine by holding the release handle out and cycle the park brake lever rapidly until I feel resistance about halfway in the travel. Depending on how out of adjustment it is, it may take a while. Doing this works the self adjuster without having to get any tools out or get under the car. I think sometimes the self adjuster just doesn't work like it is supposed to under normal use.
The Yahoo answers explanation talks about a dual cylinder drum brake. When was the last time anyone has seen one of those? If the drum brake has one cylinder like our pickups do, then there is always going to be a shoe that tries to wedge itself into the drum no matter what direction it is rotating.
  #38
Old 07-14-2014, 06:08 AM
The other Joe The other Joe is offline
The other Joe is starting off with a positive reputation.
Quote:
Originally Posted by Nothing Special View Post
30 degrees is a REALLY BIG grade, that would be a 58% grade. But it was a 30% grade mentioned (which is still pretty steep at about 17 degrees).
Thanks, I see what I did there. Would make a difference, wouldn't it.
Update on my situation.
I haven't had a chance to get the truck back in the shop. Just to busy at the moment.
But I did have to loosen up my rear brakes. I adjusted them tight and got the ebrake to hold. But the rear brakes actually tightened up.
I guess the auto adjusters tightened them up. I back down my driveway.
Anyway I am back to a poor ebrake. I am super busy. My wife and daughter do the 4 H thing. And our county fair starts this weekend. So I am going crazy getting campers, trailers and trucks ready to start moving in Thursday.
As soon as I can I will get it in and work on that front cable.
Thanks,
Joe W
  #39
Old 07-14-2014, 06:13 AM
[QUOTE=joey2fords;14499326
he can freak out to his hearts content, but in the event that ones brake pedal sinks to the floor with no stopping effort, one is much more likely to reach for the parking/emergency brake than the windshield wiper switch.[/QUOTE]
I like that last line.
  #40
Old 08-02-2014, 07:58 AM
Hi all,
I finally got time to work on the ebrake.
I went with the stretched cable theory from 1990 F350.
Since my two rear cables are fresh. I figured my ft. or middle cable was the problem.
I cut the cable and installed a turnbuckle and some clamps.
After a few tries I got it to work good. Much better than before. And with out over tightening my rear drum brakes.
I am going to pick up a bigger turnbuckle and look at making that a permanent repair.
Thanks for all the help!
Joe W
  #41
Old 08-02-2014, 08:01 AM
[QUOTE=weskan;14500680]The park brake should hold forward and reverse. If it doesn't hold reverse, then it just needs to be adjusted.
I will have to try that method.
I forgot all about that. Saves the fun of crawling under the truck with the screwdriver.
  #42
Old 08-02-2014, 08:08 AM
F350 1990's Avatar
F350 1990 F350 1990 is offline
F350 1990 is starting off with a positive reputation.
Quote:
Originally Posted by The other Joe View Post
Hi all,
Joe W
I've replaced plenty in my shop............common issue across brands, models............
  #43
Old 08-02-2014, 08:44 AM
Quote:
I have replaced some front cables before, but they were usually rusted or trashed in some way or another. Rear cables always freeze up from the salt etc. So I have replaced many of those.
But this is the first time I can remember of running into this.
I knew the ebrake should hold like my other cars and trucks have always done.
And now it does.
That's why I love places like this.
Learn something new every day.
Thanks again.
Joe W.
92 F150 E brake problem BLACKHAWK_1989 1987 - 1996 F150 & Larger F-Series Trucks 7 12-14-2016 06:27 PM
Parking brake repair rblaine1004 1999 to 2016 Super Duty 1 04-23-2016 11:07 AM
Rear E-brake adjustment? Gatordog 1999 - 2003 7.3L Power Stroke Diesel 5 07-11-2015 04:04 PM
Can't find nss 1980 F100 3onthetree 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 8 07-01-2015 12:14 AM
96 f150 E-Brakes seized :( LJ280 1987 - 1996 F150 & Larger F-Series Trucks 6 01-31-2014 03:32 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
