E brake won't hold in reverse - Page 2 - Ford Truck Enthusiasts Forums
Old 07-07-2014, 11:18 AM
dixie460's Avatar
dixie460 dixie460 is offline
dixie460 has a good reputation on FTE.dixie460 has a good reputation on FTE.dixie460 has a good reputation on FTE.
The reason they don't work so great in reverse is that the ancient relic known as drum brakes use a cam action to work, but only when rolling forward.
<a href=https://answers.yahoo.com/question/index?qid=20101127152927AAOfYbt>This</a href> post that I stole from Yahoo! Answers explains it better than I ever could:
Quote:
Originally Posted by Yahoo! Answers
In the old days drum brakes where fitted to the front and they had what was known as twin leading shoes, where each shoe had its own wheel cylinder. The shoes have a leading edge and a trailing edge and they are designed so that the leading edge contacts the drum before the trailing edge. The rotating drum picks up this leading edge and wraps it hard into the drum, magnifying the braking force. This is known as self servo action. On modern cars with only rear drum brakes they have a single leading edge and when the car is in reverse the brakes are noticeably weaker because the backward rotating drum forces the leading edge away from the drum decreasing the brake force. When the car is moving forward the self servo action occurs pulling the leading edge of the shoe into the drum increasing the braking action.
Old 07-07-2014, 11:41 AM
The other Joe The other Joe is online now
The other Joe is starting off with a positive reputation.
Hi Dixie,
All that is true. That's why they don't work as well in reverse. But it my thought that they should still work in reverse.
How else can I explain all my other vehicles being able to hold, easily I might add.
Thinking about it, I have a theory. I will try to test it.
I think it might be a pressure problem. The amount of force needed to seat the drums on the bigger truck might take more effort than say my f150 shortbed 4x4.
It might take a brake pedal that increases the amount of pull on the longer cables and heavier hardware.
What would that be? The fulcrum effect.
This is where we need someone much smarter than me.
But for testing I can increase the pull on the rear brakes and see if it works.
Thanks,
Joe W
Old 07-07-2014, 01:20 PM
tjc transport's Avatar
tjc transport tjc transport is online now
i ain't rite
tjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputation
i wonder i your front cable need to be tightened Joe.
under the cab on the driver side outside o the frame is the cable setup the two rear cables connect to the front cable with an adjustable bolt type deal. to make the e-brake hold tighter make the adjuster shorter.
unfortunately, most of the time the adjuster is rusted solid
Old 07-08-2014, 04:52 AM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is offline
Diesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud of
Quote:
Originally Posted by F350 1990 View Post
Guys ---it's a federal law (CFR) that parking brakes hold the vehicle on any grade, in any direction ..........and where in the owner's manual does it say they only work going forward?
I would like to see this "law"
Old 07-08-2014, 08:08 AM
I will have to check if it's free.
F350 1990 suggested a possible stretched cable, so I was going to see if the ft cable could be shortened, since the 2 rear are pretty fresh.
If it's free I will adjust that. If not I will experiment with it.
It rained all day yesterday so I didn't play in the drive way. My wife took the truck today.
I will play with it and see if it can be improved.
I tightened it up again and got it to hold by really pressing down hard.
Thanks for the suggestion.
Joe W
Old 07-08-2014, 08:21 AM
F350 1990's Avatar
F350 1990 F350 1990 is offline
F350 1990 is starting off with a positive reputation.
Quote:
Do you honestly believe Ford is going to put a parking brake in a car that only holds in one direction? (Ford's lawyers would have flashing hot pink warning signs all over the dash, the parking brake mechanism, and owner's manual if that were the case)
From the US Code of Federal Regulations (Nat'l Highway Transportation Safety Board)
(1) Each singly driven motor vehicle not subject to parking brake requirements of FMVSS Nos. 105 or 121 at the time of manufacturer, and every combination of motor vehicles must be equipped with a parking brake system adequate to hold the vehicle or combination on any grade on which it is operated, under any condition of loading in which it is found on a public road (free of ice and snow).
(2) The parking brake system shall, at all times, be capable of being applied by either the driver's muscular effort or by spring action. If other energy is used to apply the parking brake, there must be an accumulation of that energy isolated from any common source and used exclusively for the operation of the parking brake.
(3) The parking brake system shall be held in the applied position by energy other than fluid pressure, air pressure, or electric energy. The parking brake system shall not be capable of being released unless adequate energy is available to immediately reapply the parking brake with the required effectiveness.
Old 07-08-2014, 09:36 AM
mefast's Avatar
mefast mefast is offline
mefast is starting off with a positive reputation.
That's pretty vague and with a lot of gray areas. If you changed the direction of the vehicle, it will hold on any grade.
Ford has good lawyers and have dealt with lawsuits before (Bronco II rollovers, Firestone tires, etc).
Going back to the OP, I'm glad to hear it worked by pressing the pedal down harder as a temporary fix. Let us know what you find when you're able to look under the vehicle.
Old 07-08-2014, 11:48 AM
F350 1990's Avatar
Man --- are you kidding?
What don't your understand about the word "grade" --- car goes up or car goes down---pointy end points up or the pointy end points down.
Old 07-08-2014, 01:14 PM
mefast's Avatar
I understand it, but I could see that wording being a loophole. If the vehicle holds on a grade with it's front pointing downwards it technically does as required by law even if the vehicle wouldn't be able to hold when rotated by 180 degrees. It's all just perspective when you get lawyers involved.
Old 07-08-2014, 02:07 PM
danr1 danr1 is online now
danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.
Under FMVSS Nos. 105 it does specifically state "forward and reverse",
S5.2.1. Except as provided in § 5.2.2,
the parking brake system on a pas-
senger car and on a school bus with a
GVWR of 10,000 pounds or less shall be
capable of holding the vehicle sta-
tionary (to the limit of traction on the
braked wheels) for 5 minutes in both a
forward and reverse direction on a 30
percent grade.
Includes wording toward effort required to do so,
125Lbs if applied by foot, 90lbs if by hand. (again under 10,000lbs gvwr)
Odd they found it acceptable to limit it to five minutes though!
Yes should work in forward and reverse but it is common to loose effective hold in reverse, if shoes are worn out of adjustment by just a little bit hold suffers. If drums are at or near wear limit its even worse, best hold is when shoes and drums are new very little to no wear on them, cam action previously mentioned has all to do with it big shoe little shoe.
If rear brakes are in decent enough shape and properly adjusted it should hold "no load" at minimum.
Old 07-08-2014, 03:43 PM
mefast's Avatar
Quote:
Originally Posted by danr1 View Post
Except as provided in § 5.2.2, the parking brake system on a passenger car and on a school bus with a GVWR of 10,000 pounds or less shall be capable of holding the vehicle stationary (to the limit of traction on the braked wheels) for 5 minutes in both a forward and reverse direction on a 30 percent grade.
Thats the wording I was looking for. No more loop holes.
Old 07-08-2014, 04:57 PM
Nowhere does that say in reverse or backwards
  #28
Old 07-09-2014, 07:55 AM
Thanks for the research guys.
That's pretty much what I would expect.
I see mention of a 30 deg hill. That's a big grade. My drive way is 8% where I normally park and higher on the way up.
To the people who mentioned turning your truck around to hold on a grade.
If you do that you could/would be pointing in the wrong direction on the street. Which is illegal and would be ticketed in places. Plus you can't do that on a 1 way street.
I haven't looked at mine again. But will in the next day or two I hope. Pretty busy this week.
turned out to be an interesting topic.
Thanks,
Joe W.
  #29
Old 07-09-2014, 09:29 PM
Nothing Special's Avatar
Nothing Special Nothing Special is offline
Nothing Special has a great reputation on FTE.Nothing Special has a great reputation on FTE.Nothing Special has a great reputation on FTE.Nothing Special has a great reputation on FTE.Nothing Special has a great reputation on FTE.
Quote:
30 degrees is a REALLY BIG grade, that would be a 58% grade. But it was a 30% grade mentioned (which is still pretty steep at about 17 degrees).
  #30
Old 07-09-2014, 11:13 PM
joey2fords's Avatar
joey2fords joey2fords is online now
joey2fords is gaining momentum as a positive member of FTE.
interesting discussion ... i have owned many different american, japanese, and british vehicles and i dont recall any of them holding nearly as well in reverse as they did forward. i just came to accept it as normal. i am old school, i almost always apply my parking brake, even point my wheels to, or away from, the curb, as the situation dictates, but the real holding is done by the transmission, whether auto or manual.
had an auto trans parking pawl in my hand once and remember being surprised at how small it seemed ... but i have never heard of one breaking under normal use.
92 F150 E brake problem BLACKHAWK_1989 1987 - 1996 F150 & Larger F-Series Trucks 7 12-14-2016 06:27 PM
Parking brake repair rblaine1004 1999 to 2016 Super Duty 1 04-23-2016 11:07 AM
Rear E-brake adjustment? Gatordog 1999 - 2003 7.3L Power Stroke Diesel 5 07-11-2015 04:04 PM
Can't find nss 1980 F100 3onthetree 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 8 07-01-2015 12:14 AM
96 f150 E-Brakes seized :( LJ280 1987 - 1996 F150 & Larger F-Series Trucks 6 01-31-2014 03:32 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
