56 F-100 door latch lubrication - Ford Truck Enthusiasts Forums
Old 07-05-2014, 11:50 PM
hooler1's Avatar
hooler1 hooler1 is offline
hooler1 is gaining momentum as a positive member of FTE.
I replaced my wore out door latch and striker with new ones from Mid-50. Is the door latch mechanism supposed to be lubricated? Reason I am asking was it was working pretty good when I initially installed it (driver side door latch). Then I thought maybe I should lube up the working parts of it, so I put some Lubriplate white grease on the inside star gear and paw assembly and the out side rotor. Now sometimes the door wants to bounce back out on the 2nd click. The Ford shop manual tells you to lube the parts with a special lubricant, and it gives a C4 part number. You probably can't find that today anywhere. Anyway it got my thinking to ask what other people have used, or if it's even necessary.
Old 07-06-2014, 12:19 AM
Aus56's Avatar
Aus56 Aus56 is offline
Aus56 has a very good reputation on FTE.Aus56 has a very good reputation on FTE.Aus56 has a very good reputation on FTE.
Hello, just recently in a thread about problems with 55 doors, locking themselves when closed, Axracer commented they should be lubricated with lubriplate, never WD40 etc. Maybe they need adjustment a little, it is hard to imagine a lubricant causing a closing problem.
Old 07-07-2014, 07:03 AM
hooler1's Avatar
Thanks Aus! if Ax Racer recommends Lubriplate, then I'll use that. BTW. you have a nice truck there. Mine is the same color painted by a PO. Do you know what the actual color name is? my PO didn't and I would like to know.
Old 07-07-2014, 07:00 PM
truckeemtnfords truckeemtnfords is offline
truckeemtnfords is a splendid one to beholdtruckeemtnfords is a splendid one to beholdtruckeemtnfords is a splendid one to beholdtruckeemtnfords is a splendid one to beholdtruckeemtnfords is a splendid one to beholdtruckeemtnfords is a splendid one to beholdtruckeemtnfords is a splendid one to behold
I would never use a a grease or oil on latches and things that are exposed and not sealed. Many manufactures also do not recommend it as it collects dirt which causes wear and cause them to not move freely. I highly recommend graphite. That is what they use on locks for the very reasons I mentioned. For door latches and automotive use I recommend the spray graphite. It has a liquid that carries the graphite into the mechanism and the liquid evaporates leaving the dry graphite film behind.
P.S. Where in Iowa you from, I am from Le Mars in the NW corner.
Old 07-07-2014, 07:31 PM
AXracer's Avatar
AXracer AXracer is offline
AXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud of
I apply the grease with my finger then brush away any/all excess with a cheap stiff brush like the metal tube handled ones that usually come in a package of several.
Old 07-07-2014, 07:32 PM
Aus56's Avatar
Quote:
Thanks for your comment about my truck. I am sorry, I do not know the colour name. I love it, there are a lot of great colours around on these trucks, especially the custom stuff, but I guess for the standard colours, I really like this one. It seems whenever I saved a picture of one, it was usually this colour, and a big window, which unfortunately, mine is not. It is just a standard colour, plenty of blokes will know, I am sure.
Truckteemford, that is interesting about the graphite spray. Good to know.
Old 07-08-2014, 02:30 PM
AXracer's Avatar
You can find powdered graphite lube in small squeeze cans sold as "dripless oil" (a bit of a misnomer as it will run and drip like crazy until the kerosene carrier evaporates, shake well). I typically use it for lubing lock cylinders.
Old 07-08-2014, 07:09 PM
hooler1's Avatar
Hi Dave! I appreciate your input. Great suggestion from both you and Ax Racer about using Graphite. That's what I should of used. As far as where I am from it's Mason City. I have been through Le Mars many times. Great town! In fact I just got done with a bowl of Wells' Blue Bunny Ice Cream.
Old 07-08-2014, 08:54 PM
AXracer's Avatar
Graphite will wash away so does not add water resistance, needs to be reapplied. I figure if a latch or hinge has lasted 5 or 6 decades greased from the factory and likely never again, using a high quality grease like white lithium (lubriplate) or moly based will not collect or transfer much dirt, will resist rusting (the real killer), and with the minimal movement involved they should last a lot longer than I will.
Old 07-08-2014, 09:36 PM
hooler1's Avatar
Thanks Ax!
I ended up pulling it back out and applying some Lubriplate to it. So it looks like it should be good.
Anyone experience doors not latching when cold? Desmoface 2015+ F150 6 01-22-2016 06:41 AM
Manual door sticks AAubinoe 1968-2013 Full Size Vans 4 07-26-2015 05:33 PM
What is the proper way to adjust F150 door latch/striker? 92 Red F150 1987 - 1996 F150 & Larger F-Series Trucks 20 02-10-2015 12:30 PM
Interior door handle - catching hillcountryflt 1967 - 1972 F-100 & Larger F-Series Trucks 3 11-30-2014 12:33 PM
Which lube? WD40, Silicone, some other? kevin.ford-trucks Oil & Lubrication 6 09-17-2014 05:27 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
