Fuel Tank Sending Unit P/N
1966 Ford F100, SWB, 4x4, Styleside, NP-435, 352, in cab tank
ND, if my research is correct the P/N I have for the fuel sending unit is C1TZ-9275-C (replaced by -K), includes gasket.......would a D7TZ-9275-G be the same <compatible> part.....it looks the same from what I can tell from photos.......thanks, m.
<compatible>D7TZ-9275-G (replaced C1TZ-9275-K) .. In-Cab Fuel Tank Fuel Sending Unit / Obsolete</compatible>
<compatible></compatible>
<compatible>1961/77 F100/750.</compatible>
The COAZ-9202-B float is made from two pieces of copper soldered together. Solder breaks down, gas seeps in, float settles to the bottom of the tank.
Float same: 1957/79 Passenger Cars/Trucks, 1961/79 Econolines & 1966/79 Bronco's.
But...Carpenter sells a one piece brass float that'll never leak for around 5 bucks.
flatbedfordguy
21
06-04-2018 02:03 PM
hivolt5.0
10-23-2008 01:38 PM
doc54
13
06-08-2008 08:13 PM
