Power Door Lock Switch Side Door - Ford Truck Enthusiasts Forums
1968-2013 Full Size Vans Econolines. E150, E250, E350, E450 and E550
Old 07-05-2014, 07:56 PM
jimandnena jimandnena is offline
jimandnena is gaining momentum as a positive member of FTE.
1988 model, two hinged side doors.
The front doors have door lock/unlock switches but the side door does not. It locks/unlocks with the front doors but there is no switch to lock/unlock the front doors from the side door.
Has anyone got or added a switch on the side door?
Thanks,
jim
Old 07-06-2014, 06:08 AM
JWA's Avatar
JWA JWA is offline
JWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputation
I added a side door lock button to my '03 EB----they already come with one in the rear doors.
Being **** as I am I used Ford OEM parts, switch and pig tail connector cost about $60 for the pair. From there its simply a matter of mounting the switch and connecting it in parallel with the existing PDL circuit. I fabricated my own ersatz wiring harness, ran the wiring inside the nearest roof rib which isn't a feat for the weak or lazy.
Old 07-06-2014, 01:17 PM
Thanks, JWA. I got lucky and found a diagram in all the paperwork that came with the van.
'88 150 club wagon. by jimandnena - Ford-Trucks
I don't have any other buttons besides the two front doors on this model and I don't use the rear doors much so if I can get the side door to work, I'm a happy camper. I like the idea of staying with OEM parts for appearance but not looking forward to running the wiring, that will be the challenge.
jim
Old 07-07-2014, 07:11 AM
JWA's Avatar
JWA JWA is offline
This is what my finished (for now) new switches looks like--they're combined with interior lighting switches. First is of rear door, switch re-located from lower left of the open door to upper left for my convenience:
This is side door, tucked away from most activity to prevent accident activation:
My doors have been modified and added-to in order to better utilize what is wasted space---I work out of my vans.
Old 07-07-2014, 01:13 PM
Great job, JWA. I always looked for ways to make my life easier when I was working (5 years retired).
I thought about the location, decided the cover on the pillar was the most out-of-the-way spot and still handy while loading stuff. I got lucky (for once) and found the front door harness behind the right kick panel so I was able to run the wiring under the carpet to the pillar. Yay!
Anyway, it's all in and working, so my bride won't have to stand in the rain while I unlock her door.
Thanks for the photos and ideas! Always good to get 2nd (or more) ideas.
jim
Original and added door lock switches, '88 E150
Old 07-07-2014, 01:51 PM
JWA's Avatar
JWA JWA is offline
Thanks Jim---I like your idea and execution too! Seems we're both a bit prone to go "over the top" once we get an idea in mind!
Sometimes we get lucky and most if not all the wiring we need has already been added during factory build. I don't necessary hate too much running new wires by definitely prefer splicing into something existing.
I took my own cues from the stock location, right side rear door but recessed both switches flush with the plywood/ABS panels I installed. Even though I have a hidden key on the frame thought it was better to avoid accidentally tripping my PDL's.
Where did you get the snazzy label? Looks like I might have to ramp up my job just to keep up now.
Old 07-07-2014, 02:51 PM
That's funny. Anything worth doing is always worth doing over the top. haha
I agree on the wiring approach. When I did the selector valve install I figured a way to "repurpose" one of the sender wires to avoid pulling any new wires. Even the TFI relocate project, I used a Mustang harness as the extension, already shielded and a factory connector. (Plus I am the poster child for lazy.)
The label was an afterthought. It dawned on me that the purpose of a switch sticking out might not necessarily be obvious to everyone. And since I used to do tech drawings for training manuals, this wasn't much of a challenge. It seemed like copying the look of the factory buttons made the most sense. Printed it out on plain paper, laminated the front, spray adhesive on the back and tada.
I REALLY wanted a rocker switch but couldn't find one that would work so I went with the toggle. If I find a rocker in the future, I can swap it out easily.
jim
Old 07-07-2014, 03:03 PM
JWA's Avatar
JWA JWA is offline
Quote:
jim
PM me with your mailing address---I've more than a few that'd be suitable for this----some left over from my project. They'll be (On) Off (On) which is pretty much what the factory uses. A square hole in the B Pillar and trim might be necessary if you want them fitting close to their mounting surface.
Take a closer look at mine---they sit on a piece of 18ga sheet metal, trimmed to fit with help from a Dremel tool---and some skin I wasn't using anyway.
Old 08-10-2014, 08:54 AM
Keyless Entry Remote '88 Club Wagon
Fifteen bucks from Amazon, mounted under the hood, right side fender. Ran the wiring through the grommet into the kick panel and connected to the door lock switch wiring for the passenger door. Piece of cake and no more hassle with a door key.
Amazon -- 15 bucks
And since I was working on door locks, I ran wiring into the side door so the power locks work with the door open or closed. jim
Old 08-10-2014, 10:46 AM
JWA's Avatar
JWA JWA is offline
Wow--that's a great price on a decent looking RKE module.
I like the size of the remotes too---have tiny ones for the work van and a huge honkin' brikc for my beater car, '99 Volvo S80.
Thanks for sharing Jim!
2000 Crew Cab Drivers Side Door Lock Question stowbilly96 1999 to 2016 Super Duty 3 11-09-2016 01:47 PM
Door Locks - NOT actuator problem, please help Mr_CarMan007 1999 to 2016 Super Duty 2 03-04-2016 12:52 PM
Door lock rocker only unlocks Elmo154 Excursion - King of SUVs 1 11-17-2015 04:11 PM
Power door lock switch F350-6 1999 to 2016 Super Duty 9 12-17-2014 01:47 PM
Doors dont unlock when i pull out the key anymore kylegabbert 2004 - 2008 F150 8 12-02-2014 08:15 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
