1969 Ford F600 Cummins conversion - Ford Truck Enthusiasts Forums
Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Old 07-05-2014, 07:17 PM
OldTimerDually OldTimerDually is offline
OldTimerDually is starting off with a positive reputation.
I have a 1969 F600 and I'm looking into a 5.9 Cummins conversion. I've looked around rebuilts in my area and all I can buy is long blocks. The question I face is, after the long block, what else do I need under the hood for it to run. I figure hook up to the radiator, electrical connections to thw guages, air intake and batteries. Turbo as well maybe?
I saw a video on YouTube of 1956 f600 fire truck with a Cummins conversion and a dual transmission setup so I know it's possible. I'll post on this thread as I progress, but any help I could get would be more than appreciated.
Tom
Old 07-05-2014, 10:18 PM
6t6merc 6t6merc is offline
6t6merc is gaining momentum as a positive member of FTE.6t6merc is gaining momentum as a positive member of FTE.
In my neck of the woods a complete early 90's truck goes for a few grand and comes with everything. It might need a lot of work but it's all there.
Eric
Old 07-05-2014, 11:07 PM
Ford_Six's Avatar
Ford_Six Ford_Six is offline
Ford_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputation
Check out the 4btswaps.com forum, they have all the Cummins swap info you will need.
I would avoid buying a longblock, it's a lot of money plus a core charge plus all the additional bits you need. Donor trucks are a good way to go, pick up a Dodge and throw away the wrapper.
Old 07-06-2014, 04:25 PM
krooser's Avatar
krooser krooser is offline
krooser is gaining momentum as a positive member of FTE.
I looked at an F700 today with a 5.9 and an Allison AT-545 for $3K…
Old 07-06-2014, 11:19 PM
80broncoman 80broncoman is offline
80broncoman is gaining momentum as a positive member of FTE.
Just like post 2 and 4 say get a whole truck.
What I bought in 2010 was a 94 F700 5.9L Six speed trans had 107K
Air brakes, double frame, 10K Front, 22.7K REAR axles. Budd wheels
Cab & chassis was all that was there. Had 2 good tires.
I paid $2500 for this
I will say this, pick one that is Pre-computer (up to 1997)
Old 07-07-2014, 01:53 AM
rustyrelic's Avatar
rustyrelic rustyrelic is offline
rustyrelic has a great reputation on FTE.rustyrelic has a great reputation on FTE.rustyrelic has a great reputation on FTE.rustyrelic has a great reputation on FTE.rustyrelic has a great reputation on FTE.rustyrelic has a great reputation on FTE.
Tom[/QUOTE]
The 56 Cummins conversion you mentioned is mine, and I also recommend you get a donor truck ... I paid 2k for a 94 f700 .. all I used was the engine, fuel tank, batteries, fan shroud, tires.
Old 07-07-2014, 07:44 AM
finn finn is offline
finn is gaining momentum as a positive member of FTE.finn is gaining momentum as a positive member of FTE.
Start with a medium truck donor. Any brand truck will do as long as the powertrain layout is suitable. Pickups may have smaller radiators and lower fan centers than medium trucks, in addition to light duty transmissions.
Old 07-08-2014, 07:07 PM
The 56 Cummins conversion you mentioned is mine, and I also recommend you get a donor truck ... I paid 2k for a 94 f700 .. all I used was the engine, fuel tank, batteries, fan shroud, tires.[/QUOTE]
Awesome, your just the man I wanted to talk to. What is the 4sp spicer aux? Is spicer the brand? Do you figure the dana 80 would work on my wheels and bolts on the frame? Sorry if imw questioning too much. I'm basing my build on yours, your video is what got me started on this project.
Old 07-08-2014, 07:38 PM
Quote:
Originally Posted by krooser View Post
I looked at an F700 today with a 5.9 and an Allison AT-545 for $3Ků
Sounds like a deal. Where did you see that at?
Old 07-09-2014, 12:04 AM
rustyrelic's Avatar
[QUOTE=
Awesome, your just the man I wanted to talk to. What is the 4sp spicer aux? Is spicer the brand? Do you figure the dana 80 would work on my wheels and bolts on the frame? Sorry if imw questioning too much. I'm basing my build on yours, your video is what got me started on this project.[/QUOTE]
The auxiliary trans. Is a Spicer 6041... yes Spicer is the brand.
I am assuming that your truck has the six lug bud wheels...if that is correct, I would recommend a medium duty step van like a snap on tool truck, laundry truck, some of them use a Freightliner mt45 it has the Cummins ,manual or auto trans. And the rear end with the six lug wheels ... some of the Cummins powered f700 also have the six lug wheels. Try to find a donor that has engine and trans that you want plus the six lug wheels .... that would give you every thing you need to do the swap.
Old 07-09-2014, 01:01 AM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation
MT45s are not 6 lug*, look for an IH chassis for the 6 lug.
*none that I've seen since 1997
Old 07-09-2014, 02:19 PM
big job's Avatar
big job big job is offline
big job has a very good reputation on FTE.big job has a very good reputation on FTE.big job has a very good reputation on FTE.big job has a very good reputation on FTE.
put a 391 FT in there with od and rock. 4 bucks a gal diesel ya right.
Old 07-09-2014, 07:38 PM
Quote:
Diesel round my parts is for around $3.60. Plus, the old 5.9 Cummins could get up to 21 mpg in a 1 ton dually with 4.10s if you drove it right. My 2 ton doesn't weigh too much more than one of those trucks. With my choice main and aux trans and rear end I may be able to get tall enough gears in double over to get the same mpgs in a 2 ton so long as those giant tires don't drag me down. Just thoughts..
Old 07-12-2014, 09:49 PM
Quote:
Mine now gets 9.5-10.0 MPG towing the Jeep & trailer @ 65MPH.
Total 20,000 weight. That is with 3.58 rear axle.
Not towing when it had the 3.70 gears @ 13,000 lbs it got 11.7MPG on a 50 mile interste test run
56 f600 cummins conversion rustyrelic Large Truck 64 08-18-2016 11:56 PM
Thinking of Doing a Cummins Conversion Copterdctr 1987 - 1996 F150 & Larger F-Series Trucks 34 12-27-2015 06:33 PM
Want to keep my "3 on the tree" drockobrian 1967 - 1972 F-100 & Larger F-Series Trucks 8 04-21-2015 04:11 AM
1969 F-600 DECODE! cmongfe Large Truck 1 04-15-2015 02:19 PM
78 F150 cummins swap - cost? ErrorS Engine Swaps 2 09-09-2007 11:35 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
