'64 F250 Front Brakes.....wheel cylinder help
Guys.......I have a 1964 F250 and it is time to replace the front brakes. As you may know it has the one sided "half cylinder" that I would really like to replace. Has anyone replaced the "half cylinder" wheel cylinder with a more normal duel type cylinder? Seems like drilling a hole or two and installing one from an other year shouldn't be all that difficult. By the way, I don't want to install a disc brake kit.............If you have any ideas on what cylinder to use let's hear them.
By the way, should the front brakes have self adjusters? Mine don't!!
wheel cylinder replacement
Hi CTom, I drive a '65 F-100. It has always had the dual type wheel cylinders. I am like you, drum brakes. I wonder: This is a good place for Bill( in Ca. aka number dummey). He would know what year F250 would have used the double wheel cyl. like you want. Why don't you ask him??? He will know. He will be able to give you pics & part #'s too. Hope this helps, Cheers, Pete,
NashvegasMatt
15
03-16-2022 03:06 PM
Gramps67highboy
03-13-2015 02:39 PM
Flat Ernie
08-24-2003 10:52 AM
