code P0171 - Ford Truck Enthusiasts Forums
Modular V10 (6.8l) SPONSORED BY:
code P0171
Old 07-05-2014, 12:41 PM
wendal wendal is offline
wendal is starting off with a positive reputation.
code P0171
I just bought this 99 f250 super duty with 197k.
I changed all fluids and installed new spark plugs. I then changed the exhaust. I deleted the cat and replaced my muffler with a glass pack. Right after that I got a P0171. The pickup runs rough and jerks when driving it.
I cleaned the MAF sensor. I did replace the fuel filter. I check the pvc hose under the throttle body. It looks good.
What other hoses do I need to look at for vacuum leaks? I have read that it may be my O2 sensor.
It ran pretty good until I changed the exhaust. I did add some marvel mystery oil at the same time.
I did clear the code but still runs rough.
Another problem
My 4x4 light, service engine light does not come on when I turn the key on. All my other light come on then go off. My check engine light never comes on either.
My ABS light is on but I know what the problem is their. The left front wire going to the sensor is broke.
thanks for any help
Old 07-06-2014, 11:24 AM
Krewat's Avatar
Krewat Krewat is online now
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
Something's making it run lean.
Start by checking the fuel pressure, and make sure it's 28-30 at idle, and 38-40 with the vacuum disconnected from the fuel pressure regulator.
Any chance you have an exhaust leak ahead of the O2 sensors?
Old 07-06-2014, 02:35 PM
I will look into the fuel pressure.
I will look at the exhaust but I did not here anything.
thanks again for the help
Old 07-07-2014, 06:53 AM
CPaulsen's Avatar
CPaulsen CPaulsen is offline
CPaulsen is gaining momentum as a positive member of FTE.
Check the vacuum hoses on both valve covers.
Old 07-07-2014, 07:40 AM
OK will do.
On the passenger side does the hose crack under the insulation? Can I cut it off and then zippy tie it back on?
Old 07-09-2014, 04:37 PM
OK I am sorry for the stupid question but where is the fuel pressure regulator?
thanks
p0171 p0174 codes wont go away 9902ford Expedition & Navigator 10 01-15-2013 07:53 AM
03 Expedition: Codes P2195, P2197 and P0171 MCGA Expedition & Navigator 10 07-23-2012 11:21 PM
Engine Code Help P2196, _2197 and P0171 MCGA Modular V8 (4.6L, 5.4L) 5 04-04-2012 02:23 PM
P0171 and P0174 2000Ford2000 Modular V8 (4.6L, 5.4L) 10 12-03-2011 09:08 PM
Intake Plenum Gaskets Codes P0171 & P0174 Gulliver Ranger & B-Series 13 03-21-2010 11:34 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
