1998 F150 electrical issues, crazy
Old 07-05-2014, 09:56 AM
Rooster828's Avatar
Rooster828
Rooster828 is offline
First time posting, coming here for help, I have a 98 f150 4x4, 4.6L 150k miles, during start up the blinker indicator lights on the dash illuminated and stayed on, when trying the blinkers they did not work, but if I shut the head lights off the blinkers do work and indicators respond normally. This is the same if I turn the fan blower on, blinkers don't work and indictors stay illuminated. Also I have found that the power windows, and 4wd no longer work. other functions work such as power mirror, radio etc. all fuses under the dash and under the hood are good, I tried switching some of the relays to see if that changed anything but with no success . took the kick panel off and inspected the grounds and all seem tight. It looks like the main battery ground is just to the body and there is one solid ground from the frame to the body under the cab. all seem tight and don't appear to be corroded. any ideas? truck starts and runs great.
Old 07-05-2014, 10:05 AM
JWC 3's Avatar
JWC 3
JWC 3 is online now
Sounds like a bad gem module .
Old 07-05-2014, 10:42 AM
Rooster828's Avatar
Rooster828
yeah that's what im hearing
Old 07-05-2014, 02:48 PM
projectSHO89's Avatar
projectSHO89
projectSHO89 is offline
Still sounds like a bad ground rather than a GEM module. Blinkers, flashers, and headlights don't go through the GEM module....
Did you inspect the ground studs behind BOTH kick panels (left and right) or only one side?
Old 07-05-2014, 02:52 PM
Rooster828's Avatar
Rooster828
No I guess I did not. I will right now. Thanks
Old 07-05-2014, 03:00 PM
Rooster828's Avatar
Rooster828
What do you want for your birthday projectsho? Sob ground was backed completely out on the passenger side. And after I pulled the gem and inspected it. Where were you an hour ago, thanks a million , now to out my dash back together
Old 09-21-2014, 11:43 AM
MICHAELORR34's Avatar
MICHAELORR34
MICHAELORR34 is offline
rooster I'm having problems with my 99 ford expedition yesterday when driving down the road the o/d light started blinking and now when you put vehicle in reverse the starter engages also tried to put vehicle in neautral an crank nit and it started the vehicle just by pulling shift down
Old 09-21-2014, 11:56 AM
Bluegrass 7's Avatar
Bluegrass 7
Bluegrass 7 is offline
If you read the above past replies, your issue is not the same.
You have a DTR issue.
The switch assembly on the side of the transmission.
The OD light flashing tells you this as well.
Good luck.
Old 09-21-2014, 01:42 PM
projectSHO89
Your symptoms have nothing in common.
Please start your own thread in the most appropriate forum area instead of hijacking an unrelated one in the wrong section.
rhowardsta
1997-2006 Expedition & Navigator
15
10-11-2015 06:49 PM
apollo3519
3.8 & 4.2L V6
09-18-2008 07:19 PM
70runner
1997 - 2003 F150
06-03-2007 06:48 PM
mechgo1977
01-06-2006 08:11 AM
abigor060
1978 - 1996 Big Bronco
05-09-2005 11:41 PM
Quick Reply: 1998 F150 electrical issues, crazy
