P.B. squeak - Ford Truck Enthusiasts Forums
P.B. squeak
Old 07-05-2014, 07:32 AM
lilrobo's Avatar
lilrobo lilrobo is offline
lilrobo is starting off with a positive reputation.
P.B. squeak
i was out driving this week and i have develop a squeak when pushing the pedal , i have tried to lube things on what i see , i think it might be on the inside ? i never took a booster off the master cylinder before ,, i just dont know, its not the pedal pivot,,its kinda like a air sound too ,, i have great breaks ( power ) ,, do i need to take the booster off the cylinder ??
thanks
Old 07-06-2014, 01:08 PM
AXracer's Avatar
AXracer AXracer is offline
AXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud of
You need to put in a good sound system with a lot of volume!
Old 07-06-2014, 01:12 PM
lilrobo's Avatar
i am going to contact the people i bought it from , got to be something going on , kinda like air breaks lol
thanks
Old 07-07-2014, 06:34 PM
lilrobo's Avatar
i called them to day and they want me to check the check value ,, it was fine , no leaks , i did the test on it and while it was not running it made the sound until it pumped up and it stopped , after i started it up and it sucked more air it started to make the sound again ,, so i guess i call them again
Old 07-07-2014, 09:16 PM
avf100's Avatar
avf100 avf100 is online now
avf100 has a great reputation on FTE.avf100 has a great reputation on FTE.avf100 has a great reputation on FTE.avf100 has a great reputation on FTE.avf100 has a great reputation on FTE.
It sounds like the booster has a vacuum leak.
Old 07-08-2014, 06:47 PM
lilrobo's Avatar
i have check the check value , and it holds ,, if i take the master loose and side it out will i see anything ? or is there anything else to check,or do i need to just replace it
thanks
Old 07-08-2014, 07:00 PM
AXracer's Avatar
Check valve is cheap and easy to change. Check rubber seal it plugs into and vacuum hose for cracks. I've never seen a booster itself develop a crack or leak unless over tightened when installed. Do you have a dual diaphragm booster? If so maybe one diaphragm is ruptured?
Old 07-08-2014, 07:05 PM
lilrobo's Avatar
thanks ax
i have looked at that also it seems to fit fine ,, real snug ,,i think you mya be right about the dual diaphragm booster,, if one is bad would i still have good breaks ?? make sense for sure
thanks guys
Brake booster question / problem jasonmesq Brakes, Steering, Suspension, Tires, & Wheels 1 01-18-2016 12:48 AM
New booster. Pedal getting sucked in. 94_idi_turbo Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 0 07-11-2014 02:05 PM
Squeaky clutch pedal randy olson 1987 - 1996 F150 & Larger F-Series Trucks 2 08-25-2013 11:23 AM
chirp, squeak, and growl....would you tow? woodtrucker 1994.5 - 1997 7.3L Power Stroke Diesel 7 08-05-2013 01:32 PM
Brake Pedal Squeaking, HELP! watchfulone7 2004 - 2008 F150 3 04-27-2009 09:47 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
