Question for the ones that tow. - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 07-05-2014, 02:44 AM
Yahiko's Avatar
Yahiko Yahiko is offline
Yahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputation
If you had to get a new turn-over gooseneck hitch and companion
what would you get and why?
This is pre-purchasing research for my 2006 F350 Long Bed Crew Cab
that I already own. I just need to get a hitch other than the receiver one.
Thanks for taking the time to answer.
Sean
Old 07-05-2014, 11:28 AM
KJNDIVER's Avatar
KJNDIVER KJNDIVER is offline
KJNDIVER has a very good reputation on FTE.KJNDIVER has a very good reputation on FTE.KJNDIVER has a very good reputation on FTE.
I have a B&W flipover gooseneck and 5th wheel companion. Love, love, love it. I like it for ease of operation and the ability keep a flat bed when i need for plywood and whatnot..... swap over is easy and doesnt take long.
Old 07-05-2014, 02:46 PM
Irelands child's Avatar
Irelands child Irelands child is offline
Irelands child is a splendid one to beholdIrelands child is a splendid one to beholdIrelands child is a splendid one to beholdIrelands child is a splendid one to beholdIrelands child is a splendid one to beholdIrelands child is a splendid one to behold
I used the B&W turnover arrangement in my '06 and now in the '11, am using the same head but the new base to correspond to the Ford pucks. The best part - it's now a 20K hitch (in a Dodge, 25K !!!!) using the same head unit. Why go anywhere else. Pull it out, the truck bed is flat, no rails, brackets or other claptrap
Old 07-06-2014, 06:08 AM
Yahiko's Avatar
Thanks for the info.
Helped to make my pick.
The reason I asked was there were a
few people poo-pooing the B&W hitch with a Google search.
Sean
Old 07-06-2014, 06:19 AM
A/Ox4's Avatar
A/Ox4 A/Ox4 is offline
9 ECHO 1
A/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputation
The internet has poo-pooers for everything. I've only seen people use B&W.
Old 07-06-2014, 08:32 AM
smlford's Avatar
smlford smlford is offline
smlford has a good reputation on FTE.smlford has a good reputation on FTE.
B&W is a no brainer.
I haul my CAT 259 skid steer on a goose neck trailer (grossing about 24K) and could not be happier.
Old 07-06-2014, 06:00 PM
Ferguson65's Avatar
Ferguson65 Ferguson65 is offline
Ferguson65 has a brilliant futureFerguson65 has a brilliant futureFerguson65 has a brilliant futureFerguson65 has a brilliant futureFerguson65 has a brilliant futureFerguson65 has a brilliant futureFerguson65 has a brilliant futureFerguson65 has a brilliant futureFerguson65 has a brilliant futureFerguson65 has a brilliant futureFerguson65 has a brilliant future
I'll follow suit with whats already been said. For an aftermarket install, go with the B&W. Had one in my old truck and loved it. I've got the factory Reese in my new truck, and while not a huge deal, having to stash the greasy ball somewhere in the truck sucks. I also don't like that the round shank spins in the receiver. Guess it's not an issue, but I think the square shank B&W is a better setup.
Old 07-06-2014, 07:44 PM
walkinandout walkinandout is offline
walkinandout is starting off with a positive reputation.
b&w
Just got my companion hitch and love it jaws lock tight on king pin no problem connecting on unlevel ground
Old 07-06-2014, 10:12 PM
Hotrod70d's Avatar
Hotrod70d Hotrod70d is offline
Hotrod70d is starting off with a positive reputation.
I put a draw tite gooseneck on my truck . Tow a horse trailer just fine and it was only 320 bucks.
Old 07-06-2014, 10:21 PM
Bigpipes 35's Avatar
Bigpipes 35 Bigpipes 35 is offline
Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.
Another happy vote for the B&W companion system..
Old 07-07-2014, 01:53 PM
Yahiko's Avatar
I also should of asked who did you installation and if you
did you own how easy was it?
Once again Thank You.
Sean
Old 07-07-2014, 01:55 PM
Sean
My base system was in the truck when I bought it so I just installed the companion fifth part...
Old 07-07-2014, 03:14 PM
Hotrod70d's Avatar
Install fairly easy . Take tire and heat shield off . Drop exhaust bolt on back loose n next one up . Measure 46 3/16 from edge of bed 25 in between wheel wells drill 3 1/ 2 in hole then install . About 3 hrs . Start to finish. Thats a draw tite goose.
Old 07-07-2014, 11:15 PM
KJNDIVER's Avatar
did mine by myself, i removed the bed to mount to the frame, then measure and cut like mentioned above. Took me one afternoon to remove bed and the next morning to install, but i wasnt pushing it, i could have done it a lot quicker if needed. Not all that difficult of a project. Basically a bolt on addition....but requires a lil time...
Old 07-09-2014, 02:47 PM
spdmpo's Avatar
spdmpo spdmpo is offline
spdmpo is a splendid one to beholdspdmpo is a splendid one to beholdspdmpo is a splendid one to beholdspdmpo is a splendid one to beholdspdmpo is a splendid one to beholdspdmpo is a splendid one to beholdspdmpo is a splendid one to behold
For a long bed, hands down B&W. For a short bed 5th wheel hitch, you might want to consider one that has a sliding mechanism for turning and backing. Not sure if B&W has one like that or not.
Been a few weeks not sense getting rear ended. Yahiko 1999 to 2016 Super Duty 10 10-03-2015 08:30 PM
October, November Combined Meet Yahiko Washington Chapter 102 12-08-2014 05:23 AM
August Meet and Greet Yahiko Washington Chapter 44 08-29-2014 01:12 PM
Bad glow plug question Yahiko 6.0L Power Stroke Diesel 8 08-07-2014 11:32 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
