99 F150 ABS activates when shouldn't - Ford Truck Enthusiasts Forums
Old 07-04-2014, 10:05 PM
FordLou FordLou is offline
FordLou is starting off with a positive reputation.
Hi guys,
I am experiencing a situation about 50% of the time when driving and apply the brakes to slow down and stop. When I’ve slowed down to about 5 mph, the ABS will activate until I stop completely. No slick road surface or sewer covers. No turning. Just driving straight on dry pavement. Any ideas what is going on and how I need to approach repairing this annoying situation? Thanks for any thoughts.
Lou
Old 07-05-2014, 06:52 AM
Marty N Debbie Sapp's Avatar
Marty N Debbie Sapp Marty N Debbie Sapp is offline
Marty N Debbie Sapp is starting off with a positive reputation.
Is the light comming on or can you feel it kick in.
Old 07-05-2014, 09:35 AM
Quote:
I can feel it kick in under foot. Have not seen the light on.
Old 07-05-2014, 09:42 AM
73fan's Avatar
73fan 73fan is offline
73fan has a good reputation on FTE.73fan has a good reputation on FTE.
Sounds like you may have one bad wheel speed sensor and/or wiring. Does it have 4 wheel ABS?
Sent from Nexus 4. IB AutoGroup
Old 07-05-2014, 03:52 PM
I believe it's rear wheel ABS only but I need to call the dealer Monday to check for sure. I have rear drum and front disc. What is involved in replacing one of these for drum and for disc?
Old 07-05-2014, 06:35 PM
projectSHO89 projectSHO89 is online now
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
It would be unusual for a 99 to be RABS. Most likely, it's 4WABS. Look at your front spindles to see if there's a wiring harness going to each of them.
Most likely, you have a dirty/corroded sensor, a cracked tone ring, a damaged wire harness or a worn front wheel bearing that's causing an erratic signal from one of the sensors.
Old 07-05-2014, 07:17 PM
Is there any easy way to isolate which wheel corner has the issue?
Old 07-05-2014, 07:40 PM
You will need an assistant to do one of the tasks.
Select a safe area such as a gravel-covered drive or lot.
Driving at about 10 mph, apply the brakes sharply so as to cause either one of the front or both of the rears to lock up. Repeat several times observing to see if one front wheel (or both rear wheels) locks consistently.
The front wheel that locks indicates a sensor problem on that side or, if both rear wheels lock, the problem will be with the rear diff sensor.
Old 07-05-2014, 09:10 PM
All you have to do is look. I saw the wiring for the front wheel sensors and, I'm assuming, the rear wheel sensor also. Is it located at/in the differential? I saw a connector at the top of the differential housing. is that the sensor location or is it somewhere else on/in the rear end?
Old 07-05-2014, 11:10 PM
Torky2 Torky2 is offline
Torky2 has a very good reputation on FTE.Torky2 has a very good reputation on FTE.Torky2 has a very good reputation on FTE.
Quote:
Originally Posted by FordLou View Post
...............and, I'm assuming, the rear wheel sensor also. Is it located at/in the differential? I saw a connector at the top of the differential housing. is that the sensor location or is it somewhere else on/in the rear end?
Yup, that's it.
Old 07-06-2014, 09:44 AM
If the rear end sensor requires replacement, does it require tearing the rear end open to do it? Also, are there any other parts of the ABS system located at either of the rear wheels or is it all at the differential housing?
Old 07-06-2014, 12:27 PM
The 99 only the single sensor on top and the ring gear inside for the rear wheels. Check the sensor first since getting to the ring gear is messy and smelly.
Old 07-07-2014, 10:00 AM
Is there a way to check the sensors using a DMM set to ohms? Saw a video on Youtube showing unplugging the sensor from the harness, attaching a DMM, spinning the wheel and checking for resistance and resistance changes (it was on a 2002 and he got 535 ohms on the good replacement and 1 on the old bad one he changed out). His ABS light had been on, though, and mine hasn't. Don't know if that means a different issue in my case.
Old 07-07-2014, 10:59 AM
Set the multimeter to VAC and look for several volts when the wheel spins. The resistance check is done when the wheel is stationary and will tell whether or not he sensor is ope (usual) or shorted (unlikely).
Old 07-07-2014, 11:31 AM
Set to volts AC not DC?
High EOT's AFTER repairs. 06FUN 6.0L Power Stroke Diesel 115 10-29-2016 07:53 AM
SERIOUS light issues old blue beast 1987 - 1996 F150 & Larger F-Series Trucks 3 08-05-2016 08:28 PM
mystery problem bulletcamp 6.0L Power Stroke Diesel 17 05-16-2015 05:59 AM
Trouble Shooting Challenge - Logic Help Appreciated! Grinder Man 1997-2006 Expedition & Navigator 14 10-10-2014 09:35 AM
1996 7.3 powerstroke swap, Now cylinder contribution and transmission temp codes. Help needed. BigGreen7.3swap 1994.5 - 1997 7.3L Power Stroke Diesel 13 09-28-2014 09:21 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
