Does anyone have a head light adjustment chart for an f1 - Ford Truck Enthusiasts Forums
Old 07-04-2014, 11:03 PM
Skalywag Skalywag is offline
Skalywag is gaining momentum as a positive member of FTE.
Got all my lights working, but... my headlights are pointing toward the ground. It maybey because of the lowered front end. I know you can adjust them, so many feet from the garage wall and so many feet high for hi and low beam, but I dont remember what the height is for either. Thanks for any help and if you have a chart can you post it.
Thanks you guys are the best.
Old 07-04-2014, 11:57 PM
Jolly Roger Joe's Avatar
Jolly Roger Joe Jolly Roger Joe is offline
Just another Joe
Jolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud of
According to the Shop Manual, the F1 lights are supposed to point 31 1/8" above the ground. But they show it using a tester that nobody would own.
I adjusted my F4 to 34 1/2" against my garage wall.
But if your truck is lowered, you'll need to set it other than at the factory spec.
Old 07-05-2014, 09:28 AM
drptop70ss's Avatar
drptop70ss drptop70ss is online now
drptop70ss is a splendid one to beholddrptop70ss is a splendid one to beholddrptop70ss is a splendid one to beholddrptop70ss is a splendid one to beholddrptop70ss is a splendid one to beholddrptop70ss is a splendid one to beholddrptop70ss is a splendid one to behold
I set my headlights with a two car garage, works great. Put a known good car with the lights on in front of one closed door, park the project car with the lights on in front of the 2nd door and adjust its headlights to match the good car.
Old 07-05-2014, 09:52 AM
Quote:
That is a stroke of genius, I'll try that this evening, thanks again.
Old 07-05-2014, 01:33 PM
52 Merc's Avatar
52 Merc 52 Merc is offline
52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of
From 20 feet back on a level surface, headlights on low beam should shine on the garage door level with the lamps. Dave's trick above would be fine if both vehicles had similar height headlamps. If you're adjusting a Miata and comparing with at 4x4 pickup, you could have issues.
Old 07-05-2014, 04:21 PM
drptop70ss's Avatar
Quote:
LOL..actually it has worked ok with different height vehicles for me, putting the headlights level on a high truck just ends up blinding the guy in the car ahead of you. Setting them to match a "normal" car puts the light in front of you on the road and not in someone's rear view mirror..or up in the trees as I had at one time. I have not had anything with the headlights so low that they were an issue, generally they are pretty high even with a lowered vehicle.
Old 07-05-2014, 07:45 PM
truckeemtnfords truckeemtnfords is offline
truckeemtnfords is a splendid one to beholdtruckeemtnfords is a splendid one to beholdtruckeemtnfords is a splendid one to beholdtruckeemtnfords is a splendid one to beholdtruckeemtnfords is a splendid one to beholdtruckeemtnfords is a splendid one to beholdtruckeemtnfords is a splendid one to behold
Wayne is correct, the standard I have seen several times is; on a level surface, 25' away from a wall(or similar) main portion of the beam should be centered on wall at the height of the headlight.
Old 07-05-2014, 08:56 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is online now
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
Here's what the manual shows. 3" drop 25' away from the headlight for the high beams.
Old 07-05-2014, 09:25 PM
So what is the dimention of "B" , that seems to be the only thing missing. And thanks to all that have responded. I may get this thing adjusted despite my enthusiasum.
Old 07-05-2014, 10:20 PM
drptop70ss's Avatar
Quote:
I think the diagram shows high beams being 3" higher than low beams, or the center of the light is in a 3" window?
I bet the way I do it will be similar to the 20' to 25' rule since I am working against a known good vehicle. So far it has worked flawlessly and I do a lot of night driving. One thing about old style flat windshields, they smash bugs by the dozens at night.
My truck is going to be lower than stock so the tables wont work for me but the garage door will. If they turn out too low then I head back to the garage door and bump them both up the same amount.
Old 07-05-2014, 11:07 PM
ALBUQ F-1's Avatar
postin' fool
I think 51-52's should be called Bug-Catchers, you can easily spend an hour trying to get all the bugs out from around the headlight buckets after even a short night drive.
Dimension "B" is explained below. Basically it is to relate the headlight center to a 30" reference line drawn on the wall.
If you use your method, Dave, on a truck that sits taller, you end up with the headlights aimed too low; draw a line from the center of headlight to the point you are using as a reference, then draw a line from a headlight that starts out 4" higher to and beyond the same point on the wall. The taller vehicle's headlights will hit the ground sooner.
Old 07-05-2014, 11:26 PM
drptop70ss's Avatar
Yep, but they get set level and in line in a few minutes and if they are too low I can crank em up a bit using the door reflection to keep them even. I guess all my cars have headlights around the same height because they have been good to go first time so far. I also run a full 12v to the lamps so if they are a little off I am not sure I would notice.
I will continue to do it my way, which may not be by the manual but works for me. Drive safe
Old 07-10-2014, 01:11 AM
1oldtimer's Avatar
1oldtimer 1oldtimer is offline
1oldtimer is gaining momentum as a positive member of FTE.
25 feet away, I use my adjuster to set them and then fine tune them to my liking. You don't want them to cross or be to far apart also. I used to do testing here in So Cal to re register totaled vehicles and had a few aimers (mechanical ones and optical ones) and you can find an old Hoppy kit for fairly cheap and they work great.
I know it's a chevy site but, check it out.
Headlight Alignment - The 1947 - Present Chevrolet & GMC Truck Message Board Network
BTW, look at his tool wall........that's dedication .
correct headlight adjusting Daviddc114 1997-2006 Expedition & Navigator 13 08-04-2015 01:28 AM
flow chart and values OJJ 2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6 2 07-23-2014 05:33 PM
Ford Truck Grille Chart? coopdad General Automotive Discussion 2 01-04-2013 09:27 PM
302 power curve chart Milwaukee1979F150 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 2 12-21-2009 12:16 AM
Sealed beam interchange chart? nickmobile67 Aftermarket Products 1 11-27-2003 10:57 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
