new rear axle seals leaking gear oil. What could be wrong? - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Old 07-04-2014, 10:58 PM
nicksorenson nicksorenson is offline
nicksorenson is starting off with a positive reputation.
I put a new axle seal on the inside of the rear hub and drove it in until it seated with a small block of wood and all looked good. But I've got a brake drum that drips gear oil after a drive. I looked at the brake shoes and they're of course very oily and not working.
Could it be a bad seal? What else is there to go wrong? Seems like a simple operation.
Old 07-05-2014, 06:18 AM
427 fordman's Avatar
427 fordman 427 fordman is offline
427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.
The surface the seal sits on could be worn. Did you check it and use some emery cloth or something like it on it?
Old 07-05-2014, 06:56 AM
ReBilld's Avatar
ReBilld ReBilld is offline
ReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to behold
Where did you get the new seal? Brian (91dually) said he bought his at a parts store, put them in and they leaked. He went to ford and got them and replaced them again and all is good with those.
Old 07-05-2014, 07:54 AM
These were from NAPA. I didn't see anything rough on the mating surfaces.
Maybe I need the Ford part.
Old 07-05-2014, 10:09 AM
helifixer's Avatar
helifixer helifixer is offline
helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.
I have had that happen on a 10.25 sterling rear end, what I found was on the double lip seal the lip that was away from the oil side was so long that it would fold in to the seal lip and make a track for the oil to run through. I was using national oil seals, this truck came back 3 times before I figured out what was happening.
Old 07-05-2014, 02:16 PM
The other Joe The other Joe is offline
The other Joe is starting off with a positive reputation.
Check your vent also.
I just changed seals last week and when I blew back thru the vent hose it was blocked.
I used Timkin seals. I also cleaned and polished the heck out of my spindles to get everything as smooth as possible.
I hope they hold. sterling rear end.
Joe W.
Old 07-05-2014, 04:48 PM
Looks like a darn wasp (mud dauber) plugged the air vent tube on the differential/axle.
Bummer because now there's trash inside the the axle and maybe wear. I refilled the diff (which was drained to about the level of the axle) and took loose the axle and let it drain and what I caught I filtered through an 80 mesh filter and past a magnet and there's a small amount of fine metal in the gear oil.
Old 07-05-2014, 07:42 PM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is offline
Diesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud of
These axles have problem with seals
Ford has a $140 seal
This one requires a special tool to install the wear sleeve before the seal
Also, it takes a thinner bearing
and then there is the ScotSeal # 34384
the wear sleeve must be removed BEFORE this seal is installed
Both seem to fix the leak
Old 07-05-2014, 11:59 PM
I took a garden sprayer and pumped about 1.5 Gallons of Diesel through the offending axle and out the diff (cover off) about 10 times and was getting all kinds of trash in my catch pan that looked like pieces brake dust (non magnetic) even after 10 times. There's less of it in there but man did this turn into a big job all because of a wasp plugging the vent tube. The other axle looked ok for grime.
One thing that gets me though is that the axle seal lives in a very dirty environment (the brake drum). I don't know how these don't leak. I have just a single lip seal (not sure if that's how these are supposed to be) and I don't see how with all of that brake dust, it doesn't eventually break the seal.
Old 07-06-2014, 09:19 AM
And right there is your problem
Old 07-06-2014, 10:15 PM
Quote:
It's been a while but I'm sure I compared the seal I removed to the new and I could almost say for certain that they looked similar. The seal that was there when I bought the van looked as if it'd been there for quite a while and to my knowledge it wasn't leaking when I got it.
Old 07-07-2014, 06:16 AM
And like I said earlier. These axle have problems sealing so they came out with the wear sleeve style(ford) and the Scotseal(aftermarket) to fix the problem
Old 07-07-2014, 12:44 PM
Groundpounder0331 Groundpounder0331 is offline
Groundpounder0331 is starting off with a positive reputation.
Hey Nick. Been there, done that, and got the T-Shirt. Read this thread I posted back in 2010. Had the exact same problem and drove myselft crazy trying to fix the leak. This should fix your problem!
http://www.ford-trucks.com/forums/971194-lessons-learned-rear-hub-seals-wheel-bearings.html#post9071995
Old 07-09-2014, 10:47 AM
Cleaned the vent tube (plugged solid) and so far it seems to be ok!! Very happy about this! No seal change yet (with the existing NAPA seals). So it looks as if the plugged vent was the problem. This is in a E350 (Dana 60) but I believe the hub/spindle seal is the same as on other rear ends.
Old 07-09-2014, 04:01 PM
I love the easy solutions. Glad to hear.
Rear axle seal or brake caliper JNG6 1999 to 2016 Super Duty 16 02-09-2016 11:54 PM
New 9" Axle Seal Failure 94150 1973 - 1979 F-100 & Larger F-Series Trucks 14 12-27-2014 10:31 PM
Rear axle seal leaking into brakes -- Sterling 10.25 quakerj 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 4 11-26-2014 10:23 PM
Rear Inner Seal leaking... nodesy 1999 to 2016 Super Duty 3 07-05-2014 11:41 AM
1983 Rear axle seal part number? ajsanteiro 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 8 11-22-2012 01:09 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
