Fluid change intervals on 7k km/yr usage - Ford Truck Enthusiasts Forums
Old 07-04-2014, 06:58 PM
Zoltrix Zoltrix is offline
Zoltrix is starting off with a positive reputation.
Hey guys,
Been wondering what I can really get away with on fluid changes for my 97 4.6.
Its got 265k km on it, I have had it since 2000 and I have in the past religiously changed fluids at regular recommended intervals,
Engine oil every 5k km
Coolant 50k km or 2yrs
Transmission 50k km or 2yrs
Differential 25k km or once a year.
Well, I now have a company vehicle and a second car with the old lady, the truck is my second vehicle when the old ladies out or we go camping. Its averaging 7k km a year over the last 4 years
I have heard engine oil will breakdown over time and should be changed a minimum of once a year.
Haynes recommends coolant and transmission fluids changed out once every two years.... but its really hard justifying changing out transmission fluid with only 15k on it... Am I wasting my time to change it out every 2 years just because its "old" or can I get 4 out of it? Same for Coolant and Differential.
I'm curious if anyone has any "facts" about fluids breaking down or not over time by just sitting there, or if its all a matter of opinion.
Old 07-04-2014, 10:56 PM
steve(ill)'s Avatar
steve(ill) steve(ill) is offline
steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.
I would change the motor oil once per year. The transmission and differential are sealed and will be good forever. How about the extended life antifreeze (yellow) and leave it in for 5 years.
Old 07-06-2014, 02:04 PM
I did just put the 5yr antifreeze in a few months back
Old 07-06-2014, 11:13 PM
Dr. Dirt's Avatar
Dr. Dirt Dr. Dirt is offline
Dr. Dirt is gaining momentum as a positive member of FTE.
on the engine oil I would change it at least once a year. if it's always getting short trips then the engine doesn't get hot enough to burn the condensation/water out of the oil.
in midyear 2002 the ford trucks including the diesels switched to gold coolant which is longer life coolant than the green. it doesn't hurt the older trucks to put gold in it.
Problems to date with my 2010 Escape Tomcat55 Escape & Escape Hybrid 6 05-22-2016 08:41 PM
My V10 sea foam experience, and your thoughts Jmoen7 Modular V10 (6.8l) 9 08-04-2013 08:40 PM
Automatic Transaxle- Fluid Question, Non-Ford texastech_diesel Clutch, Transmission, Differential, Axle & Transfer Case 1 08-07-2011 01:17 PM
100k maintenance items F-150man Ranger & B-Series 4 01-08-2011 03:59 PM
98 explorer servicing crandell85 Explorer, Sport Trac, Mountaineer & Aviator 1 04-18-2007 09:45 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
