What's missing from my accelerator linkage?
51 F4 226 6 cyl. My pedal rod barely pokes through the firewall.
Here's a pic of what I have sticking up through the floor. I'd like to order whatever is missing, but I can't tell from the drawing what goes where or how it's supposed to work.
Looks like I need a 7HC 9738-B Pedal to Accelerator Rod, and the 7HC 9760-B Accelerator to Pedal Rod Spring. Does it look like the 9738 is maybe broken off in the pic? How does that part attach to the 9725 Accelerator Assy? It doesn't look threaded in the drawing.
And where does the *23499-S8 Pedal Stop Carriage Bolt mount? I don't think I have one...
The 33798-S8 and 34806-S is a nut and lock washer and looks like it holds the assembly to the firewall.
The only part I can find for number *9794 is a "Generator Mounting Cup" and that's not what I need...
And I can't find any 8112177 part in my book although I think that would be a common rubber replacement part. Mine is obviously worn down.
Can anyone help?
Can anyone help?
Is that the spring in your picture? It just kind of threads on by twisting, likewise the 9738 similarly twists into the spring. It kind of looks like the ball end broke off your 9738.
Accelerator Pedal Seal | Dennis Carpenter Ford Restoration Parts
http://www.macsautoparts.com/ford_tr...pedal-rod.html
PS -- see if the ball end is stuck inside the rubber socket on the back of your accel pedal
I didn't have a pedal when I got the truck. I just tried to "unscrew" the part that's there and it won't budge. Probably needs to be blasted like everything else. If it is a broken 9738, it's really twisted onto that spring...
I see Dennis Carpenter has all the parts. Thanks again Ross.
Ford had odd ways of looking up body parts back then.
What the basic part number actually is: 12177 not 8112177
When you look up this number, by adding the body style (81), the prefix and suffix (if any), the entire number will be known.
You need the 1944/52 body parts catalog to look this number up.
So, just to be sure I understand, I looked for that number (12177) in my Parts Catalog, and of course you're right Bill, it's not in there.
One of these days (how many times have I said this?) I'm going to take you up on picking up the parts book you offered. But I made my Illustrations and Text catalogs searchable PDFs now, so I am finding things easier.
Thank you Ray
While I was in Denver this week, I received at home in the mail a gift from Ray... He obviously spent some time cleaning it up before he sent it.
And now that I see what this really looks like, I don't know what I have stuck on the end of the gas pedal rod...
But it isn't anything like that.
I've been driving my F-2 for over 20 years with a pedal, just the rod sticking through the floor. The other day while driving the panel I realized I didn't have a pedal in that truck either. I guess I've just come accustomed to it. I do have pedals for both trucks, they're in my parts stash but just have never taken the time to install them.
So that's when I looked in the parts catalog to see what that stub is supposed to look like, and discovered I have parts missing. I'm not surprised... just learning something new about the truck.
olguy317
08-19-2016 10:40 AM
awjjim
08-31-2014 01:23 PM
pineconeford
08-06-2013 09:40 PM
Ed Bamba
04-06-2011 09:57 PM
