Highboy manual steering - Ford Truck Enthusiasts Forums
Old 07-04-2014, 04:58 PM
Pvt dirtpusher Pvt dirtpusher is offline
Pvt dirtpusher is starting off with a positive reputation.
I have been reading this site for years absorbing the knowledge on this website. Thanks guys for the wealth of information.
I received a 77 f250 4x4 highboy from my brother after he botched and never finished the 78,79 power steering swap. He decided that he didn't want to cut the crossmember to but the new gear in and placed it to far forward. Doesn't help that his welds look like crap and he didn't grind anything down. Pictures tomorrow when I pick up the truck
Basically everything needs to be cut out and redone. But in order to get the truck running and driving until my shop/welding skills are up to par I want to put the manual gear box back in. Only issue is my brother lost the pitman arm and I can't find it any where.
Does anyone know where I can find it or if that pitman arm is interchangeable with a f100 4x4 or any other f series truck with a manual gear box? Or are they all separate arms?
Thanks!
Old 07-04-2014, 06:29 PM
mikeo0o0o0's Avatar
mikeo0o0o0 mikeo0o0o0 is online now
mikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud of
Arm, steering sector shaft
Fits:
76-77 F250 4WD before s/n Y20,001
D6TZ-3590-C marked D6TA-3590-HA, NA
2WD uses a completely different steering setup and won't work.
Unfortunately I couldn't locate any dealers or obsolete parts suppliers that have one.
EDIT: I did find one. NOS Parts in Waxahatchie, TX has one but its a gagger on price $185.00!
http://www.nospartsltd.com/product-p/d6tz3590c.htm
Old 07-05-2014, 04:21 PM
Thanks for finding that. But holy crap is that an expensive part. I guess I will just call every junkyard I can find
Old 07-05-2014, 04:39 PM
mikeo0o0o0's Avatar
Yeah, that's pretty bad. The problem is, most obsolete parts suppliers know when they have the "one and only" part. If it's something critical like the steering arm then the sky's the limit.....how bad do you want to drive your truck? is pretty much how they price parts.
You should also post a WTB add here on FTE. There has to be a member out there that has one of these laying around.
Old 07-05-2014, 04:43 PM
redroad's Avatar
redroad redroad is offline
redroad has a good reputation on FTE.redroad has a good reputation on FTE.
Quote:
Check your visitor messages
Old 07-06-2014, 02:25 AM
montana_highboy montana_highboy is offline
montana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud of
That can be a hard pitman arm to come by, only the 76/77 highboy use that particular arm, the 67/75 highboy pitman arm is 2" shorter. If I can find one at my local yard you can have it for cost, plus shipping, it won't be for a couple weeks though.
Steering gear install 99expyTN 6.4L Power Stroke Diesel 4 10-28-2014 01:07 AM
Toyota MANUAL Steering Box Pitman Arm Issue okedokeno 1948 - 1956 F1, F100 & Larger F-Series Trucks 28 10-26-2012 11:45 PM
Toyota Box Pitman Arm Source - For Sure This Time! BlueOvalRage 1948 - 1956 F1, F100 & Larger F-Series Trucks 21 05-15-2010 05:23 PM
'73 F250 Power Steering Conversion MagickNinja 1973 - 1979 F-100 & Larger F-Series Trucks 1 02-09-2010 06:41 PM
Where to buy manual steering pitman arm glenn Allen 1973 - 1979 F-100 & Larger F-Series Trucks 10 10-12-2008 10:49 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
