Please help with parking cable - Ford Truck Enthusiasts Forums
Old 07-04-2014, 01:54 PM
brokersteve's Avatar
brokersteve brokersteve is offline
brokersteve is starting off with a positive reputation.
I have a 78 F150 4x4, and am replacing my drum rear brakes. I don't have any experience with drum brakes, and started with the driver side. Apparently, whoever worked on them last, had everything backwards. I have a shop manual, and everything is shown backwards. I have a new parking brake cable and am trying to figure out where, inside the drum, it attaches. I took before pics, but cannot see where it was connected previously. Here is what it looks like:
20140704_133520_zps13ee7c40.jpg Photo by brokersteve | Photobucket
I also have this bracket that I THINK held the cable, but was routed on the right side, in the hole where the adjuster bracket (silver bracket in photo). When I took it off, there was no adjustment bracket or cable installed. Here is a pic of the bracket:
20140704_133650_zps32ea69ab.jpg Photo by brokersteve | Photobucket
And the other side:
20140704_133657_zpsda8348be.jpg Photo by brokersteve | Photobucket
Can anyone tell me where I need to attach the parking brake cable? I've got the truck halfway out of the garage, and need to be able to close it tonight... LOL.
Old 07-04-2014, 03:09 PM
mikeo0o0o0's Avatar
mikeo0o0o0 mikeo0o0o0 is online now
mikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud of
Here's mine, this is the passenger side.
With brakes the left and right sides are mirror images of each other. When you're looking at it, don't think left or right, think front and back.
Old 07-04-2014, 03:18 PM
mikeo0o0o0's Avatar
The parking brake lever attaches to the rear shoe and is held in place by the c-clip (yellow circle).
The brake cable attache to the little hook at the bottom of the arm (green circle). You pull the spring back, place the cable in the slot and then let go of the spring to keep everything in place.
Old 07-04-2014, 03:19 PM
mikeo0o0o0's Avatar
Also, notice that the shoes are two different lengths, The shoe with the shorter lining goes to the front of the truck.
The adjusters and the adjuster link are side specific and should be marked "R" or "L".
What you said about the PO having everything backwards may or may not be true. Like I said, the right and left side are mirror images of each other. You have to think, "okay it's towards the front on this side, so that means it will be to the front on the other side too.
If you think in terms of right and left, you're going to screw yourself up. Thinking like that, you would have to think, "okay, on this side, it's on my right. That means on the other side it'll be on my left".
It's a lot easier to think front and rear.
If you look at the illustration and it looks backwards to what you're looking at, it could be an illustration of the opposite side.
The reason you're having trouble with the parking brake cable is it looks like you left the actuator arms off. These go behind the rear shoe and in the pictures are kinda hidden by the shoe.
Old 07-04-2014, 04:48 PM
Thanks for the replies. I actually found that pic Mike posted in a previous post and it helped. The PO did have a lot of it backwards. The issue is that the new parking cable has a ball on the end, whereas the original cable has a round block stop and is fronted by a long spring. The way the bracket is bent at the end that holds the cable, it seems as though the ball might slip off the bracket. Looks like to hold it better, it should be bent the other direction so it will cup the ball on the cable. Do you think I have the wrong cable?
Thanks for letting me know the pads were different sizes. I was not aware, so will need to go check to make sure it's right. The passenger side went MUCH quicker after I put the drivers side together.
Old 07-04-2014, 04:52 PM
I just went out and measured. All my shoe pads are the same length?
Old 07-04-2014, 05:14 PM
Correction. I just realized it is supposed to be the shoes with the thinnest pad goes toward the front of the truck, not the shortest pad. I understand now.
I would still like some advice on the parking cable with the ball end.
Old 07-04-2014, 05:47 PM
OldMetal's Avatar
OldMetal OldMetal is offline
OldMetal is gaining momentum as a positive member of FTE.
Quote:
No, go back and look at Mikes photo, notice how much higher the rear pad goes up on the shoe! This is important so take your time and make sure you understand
Old 07-04-2014, 06:13 PM
mikeo0o0o0's Avatar
The ball end is just a different style of cable stop. It won't slip off.
Look at the picture, the spring is captive by the bend in the arm and will keep the cable from moving sideways to allow the ball to come loose.
If that wasn't the case, the cable would come loose whether it was a ball or cylinder.
Old 07-04-2014, 06:22 PM
mikeo0o0o0's Avatar
Yeah, the shoes should be two different lengths of lining on them.
Old 07-04-2014, 06:41 PM
OldMetal's Avatar
Quote:
Steve please note I was using your terminology but Mikes is the correct one, the pads on drum brakes are called linings, the shoe is the metal part. Hope this clears up any confusion
Old 07-04-2014, 09:29 PM
Thanks for the quick replies. I finally figured everything out. The parking cable I have does not go to the drum, it goes from the equalizer bar to the pedal, LOL. I figured that out once I buttoned everything up, and went to connect it to the equalizer. It was WAY too long. So, all in all, I took each side apart and reassembled no less than 5 times total. Parking cable, shoe lining in wrong position, etc. I think I made every possible mistake. Of course, no I feel I could do it again with no reference. Bled the lines and everything seems to work well. I did not test but to turn around in driveway though. I've read on here someone suggest hitting the brakes hard to set the adjustments, is that correct? I'm used to disk brakes where you take it nice and easy with slow, uniform braking for a while. What's the proper way to break in the drums? Thanks again.
Old 07-04-2014, 10:41 PM
mikeo0o0o0's Avatar
Adjust the brakes until there is a light drag on the drum when you spin it by hand.
Just so you know, the automatic adjusters only work when you hit the brakes in reverse. That's when the slight rotation of the shoes will put tension on the adjuster cable and, if there's enough travel, click the shoes out one notch.
Old 07-05-2014, 01:04 AM
OldMetal's Avatar
Glad you got it all worked out, it may have took you a while but look at what learned! There's nothing better than driving around in a truck you fixed by yourself. Good job!
Old 07-05-2014, 09:37 AM
I didn't realize that's how it worked. Good to know.
Big Ed gets a Facelift, Aussie Headlights on the Bricknose. DarrinGT 1987 - 1996 F150 & Larger F-Series Trucks 40 04-13-2015 09:30 AM
2014 F250 Platinum Mixed Breed PICS Cajunboxer 6.7L Power Stroke Diesel 7 09-12-2014 03:30 PM
Stock height of 2wd supercab? brokersteve 1973 - 1979 F-100 & Larger F-Series Trucks 2 02-10-2014 10:54 PM
Anyone like Pontiacs? Icefan71 General Automotive Discussion 6 10-03-2013 07:24 AM
Test Pic Wy Roadblock User Gallery & Picture Display 3 03-31-2013 11:57 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
