Chatter - Ford Truck Enthusiasts Forums
1968-2013 Full Size Vans Econolines. E150, E250, E350, E450 and E550
Chatter
Old 07-04-2014, 11:25 AM
jeffnick jeffnick is offline
jeffnick is starting off with a positive reputation.
Chatter
'05 E350 V10 limited slip 120,000 miles.
Lately I've been noticing a slight chatter when going around a corner after a stop. As soon as I straighten her out the chatter stops.
I have a buddy with a 2010 F150 and noticed the same thing happens to him.
Is it the rear end?
Is this something to worry about?
Is there a fix?
Old 07-04-2014, 03:42 PM
gman97005's Avatar
gman97005 gman97005 is offline
gman97005 has a good reputation on FTE.gman97005 has a good reputation on FTE.
I would take it to a shop that specialises in rear differentials, definitely sounds like a posi-traction related issue..
Old 07-04-2014, 04:02 PM
YoGeorge YoGeorge is offline
YoGeorge is a splendid one to beholdYoGeorge is a splendid one to beholdYoGeorge is a splendid one to beholdYoGeorge is a splendid one to beholdYoGeorge is a splendid one to beholdYoGeorge is a splendid one to beholdYoGeorge is a splendid one to beholdYoGeorge is a splendid one to behold
Many posi units will chatter when you lift the inside rear wheel. You could moderate the chatter a bit with some limited slip additive, but that will make the gear oil more slippery and in theory cut down the locking effectiveness of the diff when you do need traction.
I had an Eaton posi installed in my '02 when it was new and it will occasionally chatter when lifting the inside wheel on wet pavement, but am not really concerned. It's due for a diff oil change and I might ask for a little bit of extra additive at that time. The Ford OEM trac lock and my Eaton are both clutch type units; there are smoother gear type units on the market, but they all have their downside.
I take my chattering as a sign that my posi is still working....
And then there are pure lockers which are much more abrupt in their action--basically the outside wheel in a turn unlocks and freewheels. The lockers will be much tougher in terms of drivetrain shock.
It really shouldn't hurt anything unless you perceive the chattering as causing violent shocks to the drivetrain.
Good luck,
George
Old 07-04-2014, 04:19 PM
gman97005's Avatar
Before adding 1 drop of any additive to any rear differential, take it to a shop that specialises in rear differentials..
Old 07-05-2014, 05:28 PM
Thanks guys. I'll live with it a while, then decide what to do.
Clutch Chatter lalberts 1973 - 1979 F-100 & Larger F-Series Trucks 9 12-04-2016 10:34 PM
2014 f350 1 gear chatter Scoobert 1999 to 2016 Super Duty 15 10-28-2015 12:16 PM
Auburn limited slip chatter expectations? Tectron1 Clutch, Transmission, Differential, Axle & Transfer Case 4 04-10-2015 10:54 AM
99 3.0 Chatter trukerdanz Ranger & B-Series 9 02-16-2015 06:50 AM
1997 F350 relay #2 under hood fuse box superdutyf450 1994.5 - 1997 7.3L Power Stroke Diesel 1 11-24-2014 09:32 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
