front brake hoses - Ford Truck Enthusiasts Forums
front brake hoses
Old 07-04-2014, 09:53 AM
tomrflorida tomrflorida is offline
tomrflorida is starting off with a positive reputation.
front brake hoses
I put a Heidts Mustang 11 rack & piņon kit on my 49 Ford F1. I though I had it all set but I can't get the brake hoses where they will not get hung up by the springs sometime down the road. The kit comes with what they listed as 82-87 Camaro calipers. The calipers mount on the back of the wheel and the brake hoses will go towards the front of the truck.
What hoses are you using and can you post pictures of what you did?
Old 07-04-2014, 12:45 PM
drptop70ss's Avatar
drptop70ss drptop70ss is online now
drptop70ss is a splendid one to beholddrptop70ss is a splendid one to beholddrptop70ss is a splendid one to beholddrptop70ss is a splendid one to beholddrptop70ss is a splendid one to beholddrptop70ss is a splendid one to beholddrptop70ss is a splendid one to behold
Curious why your brake hoses go towards the front of the truck? Every car I have had has the hoses going towards the rear away from the suspension.
Old 07-04-2014, 01:54 PM
Rimrock F1's Avatar
Rimrock F1 Rimrock F1 is offline
Rimrock F1 has much to be proud ofRimrock F1 has much to be proud ofRimrock F1 has much to be proud ofRimrock F1 has much to be proud ofRimrock F1 has much to be proud ofRimrock F1 has much to be proud ofRimrock F1 has much to be proud ofRimrock F1 has much to be proud of
This is a Mustang II on a F-1 with Camaro brakes. The hoses stay to the rear.
Old 07-04-2014, 05:11 PM
carnut122's Avatar
carnut122 carnut122 is offline
carnut122 is gaining momentum as a positive member of FTE.carnut122 is gaining momentum as a positive member of FTE.
I'm using the TCI stainless steel hoses that came with the TCI M2 kit(which I'm pretty sure is pretty much what you have(design-wise and parts-wise). I had the hardpoints so the hoses exited to the rear, and likewise, I could find no way to keep them out of the coil springs(upon full turn). I finally gave up and moved the hard mounts to the front of the truck and I've had no problems since. I don't have any pictures and it may be awhile before I can get you some.
Old 07-04-2014, 05:14 PM
carnut122's Avatar
Quote:
Mine were like that, but upon full turn, the hose would enter between the coils on the spring.
Old 07-05-2014, 05:47 AM
What do you mean by the hard points ? On my clippers there is a recess that the hose must go in and it makes the hose go towards the front. I took pictures but I do not know how to post them here.
Old 07-05-2014, 07:18 AM
carnut122's Avatar
Hard points would be the non-moveable points where the hose attaches to the frame. I welded mine on, so that was not predetermined in my application. My calipers also had the slots pointing towards the front of the truck.
To post picture:
Open a Photobucket account and upload pictures to that account.
Copy the URL of a picture you want to post.
Click on the yellow (insert image) "landscape" image above (when you're in the "Go Advanced" posting window).
Paste your URL into the box and you should be done.
Old 07-05-2014, 10:30 AM
Size:  62.1 KB This is a picture of how the brake hose mounts
Old 07-05-2014, 04:32 PM
drptop70ss's Avatar
I just parted out an 86 Z28 last week, the front brake hoses are very long and if you used them you may be able to have them run up around the front of the caliper like the Z did. The z28 has struts up front and the springs are way inboard of the brakes, there is a mount on the strut that the hose clips to before it turned towards the rear of the suspension. I have the calipers in the garage but I dont think I have any monte ones left to compare to.
Other option is possibly you could use 1980-88 monte carlo calipers. They use a regular coil spring suspension and may have the hose connection point in a better spot. Just have to confirm the mounting bolts are in the same location.
2003 Brake Caliper Sticking daveplot Expedition & Navigator 6 08-21-2015 06:46 AM
Best Calipers, Front Brake Hoses and Brake Fluid for 1995 F-150/Bronco ? Tim Hodgson 1978 - 1996 Big Bronco 4 01-19-2015 10:35 AM
Best Calipers, Front Brake Hoses and Brake Fluid for 1995 F-150/Bronco ? Tim Hodgson 1987 - 1996 F150 & Larger F-Series Trucks 2 01-14-2015 07:34 AM
Left front caliper; weak pressure? simulatedjim 1999 to 2016 Super Duty 8 08-09-2014 08:51 PM
Rear Caliper Banjo Bolt Size?? Aftrmidnite 1997 - 2003 F150 0 07-10-2011 06:45 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
