Sure, AE should be spot on. At 26v it's getting close to repair time. How are the batteries/charging system voltage, and FICM main power?
FICM main power is jumping from 45.5 to 48.5V while running. I'm a little nervous about that. As far as the charging system, I don't have a load tester, but I'm dying to test the batteries. I also need to test the alternator. I know that both play a crucial part in a properly functioning FICM. I also know that a faulty charging system could actually destroy an FICM and also your injectors. Do you have any ideas for checking the batteries under load? Is there a "home brew" load tester? Thank you again for your help, much appreciated.
Anybody know anything about the Aeroforce Interceptor? I have been looking at it for awhile and it has lots and lots of sensor readings. Everything you could ever want. Looks really good. I am wondering if anybody has any experience with it? Looks like a good deal. Any advice is helpful. Thanks.
