f350 donor truck? - Page 4 - Ford Truck Enthusiasts Forums
f350 donor truck?
  #46
Old 07-09-2014, 07:31 AM
dylansf23's Avatar
dylansf23 dylansf23 is offline
dylansf23 is gaining momentum as a positive member of FTE.
So I'll take em to a 4x4 shop and see their weight load, and then drop a leaf or two. Is that the proper term? Leaf?
  #47
Old 07-10-2014, 04:26 AM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is offline
Diesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud of
They only have 2 leaves to begin with and you cannot change the spring weight rating. You need to change the spring
Solid axle swap and lift rowdyredneck 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 7 11-20-2016 02:04 PM
1/2 ton SAS (Solid Axle Swap) guide 9.ford.5 Offroad & 4x4 137 10-30-2015 12:54 AM
D60 SWITCH PlumCrazy7 1987 - 1996 F150 & Larger F-Series Trucks 14 04-04-2015 12:02 PM
F250 4x4 Front axle options - D60 SAS? 63nova86F250 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 0 03-29-2012 08:10 PM
Ford F250 TTB TO D60 SAS Questions nossliw Offroad & 4x4 12 11-30-2011 08:43 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
