f350 donor truck? - Page 3 - Ford Truck Enthusiasts Forums
f350 donor truck?
  #31
Old 07-05-2014, 08:49 AM
f100beatertruck's Avatar
f100beatertruck f100beatertruck is offline
f100beatertruck has a very good reputation on FTE.f100beatertruck has a very good reputation on FTE.f100beatertruck has a very good reputation on FTE.f100beatertruck has a very good reputation on FTE.
I thought the F 350's stayed leaf and the f250's had coils. Or is that just up to 06?
  #32
Old 07-05-2014, 09:02 AM
Rogue_Wulff's Avatar
Rogue_Wulff Rogue_Wulff is offline
Rogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to behold
F350 4wd did go to coils up front. I don't know what year the change was made.
  #33
Old 07-05-2014, 11:36 AM
dylansf23's Avatar
dylansf23 dylansf23 is offline
dylansf23 is gaining momentum as a positive member of FTE.
ahh okay.
i was wondering if i could get a rolled/heavily damaged 99-03 truck and steal the axles and scrap the rest.
  #34
Old 07-05-2014, 11:46 AM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is offline
Diesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud of
05+ were coil spring
The 99-04 were leaf spring and unless it was a dually, 99-01 were all dana 50 front axles(f250 or F350) But different perch width that the 80-97 trucks, custom spring hangers, you need a custom track bar and custom track bar mount. They still have the POS unit bearings(unless you spend $1200 on the DYNATRACK bearing setup) Overall, a bad idea.
But they still have the metric pattern. And putting adapter/spacers on the unit bearings is not a good idea. 05+ duallys went to a 8 on 200mm pattern
I typically sell Dana 60s for 850. Matter of fact i just sold one on monday. I try to keep 2 in stock at all times
  #35
Old 07-05-2014, 12:05 PM
Brad, did you mean to say the front axles were D60? Rather than D50?
  #36
Old 07-05-2014, 12:13 PM
dylansf23's Avatar
but how much worse are adapters on wheel bearings then not changing lube and greasing them every 100k? or 36" tires for that matter
  #37
Old 07-05-2014, 01:23 PM
Quote:
Negative
99-01 were all Dana 50 In F250s, F350s Single wheels and Excursions. ONLYDuallys got Dana 60s
Then in 02 F250s and F350s got Dana 60s, but the excursion kept the Dana 50
Also the excursion kept the leaf springs till the end of production in 05
  #38
Old 07-05-2014, 06:26 PM
Negative
Did not know that. I thought the D50 went away when the TTB (finally) died.
  #39
Old 07-05-2014, 07:32 PM
No. They still used them. Almost identical to the 60 in appearance. The ONLY way to tell from the outside is the size of the pinion nut
  #40
Old 07-05-2014, 10:42 PM
Well, I'll be. Learn sumthin new everday.
I do a lot of work on these kinds of rigs, but mostly stuff above the axle....
  #41
Old 07-07-2014, 04:04 AM
dylansf23's Avatar
Okay guys. I found.a great donor. 92 f350 idi 5speed( buddy is gonna take the tranny and other stuff for his 86 idi, auto to manual) 4x4.
I'm gonna use the springs with it and blocks so I get an even ride height.
Also looks like it has hydroboost, so might be doing that too, although I might need abs for that.
Full truck minus bed, grill and dash.
  #42
Old 07-08-2014, 06:01 AM
What engine is in your truck?
  #43
Old 07-08-2014, 08:17 AM
dylansf23's Avatar
Straight six.
Also have an ext cab idi.
  #44
Old 07-08-2014, 08:18 AM
ArdWrknTrk ArdWrknTrk is offline
pedant
ArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputation
He's mentioned in post #7 that he has a 300.
  #45
Old 07-09-2014, 05:56 AM
Then the diesel springs will be WAY to heavy for you and will ride like crap
Solid axle swap and lift rowdyredneck 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 7 11-20-2016 03:04 PM
1/2 ton SAS (Solid Axle Swap) guide 9.ford.5 Offroad & 4x4 137 10-30-2015 01:54 AM
D60 SWITCH PlumCrazy7 1987 - 1996 F150 & Larger F-Series Trucks 14 04-04-2015 01:02 PM
F250 4x4 Front axle options - D60 SAS? 63nova86F250 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 0 03-29-2012 09:10 PM
Ford F250 TTB TO D60 SAS Questions nossliw Offroad & 4x4 12 11-30-2011 09:43 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
