f350 donor truck? - Page 2 - Ford Truck Enthusiasts Forums
f350 donor truck?
Old 07-04-2014, 09:17 AM
dylansf23's Avatar
dylansf23 dylansf23 is offline
dylansf23 is gaining momentum as a positive member of FTE.
i can email you the pics he sent me if you want to pm your address?
Old 07-04-2014, 09:26 AM
ArdWrknTrk ArdWrknTrk is online now
pedant
ArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputation
Quote:
Originally Posted by dylansf23 View Post
side note, how do you like the pmgr starter?
PMGR starter is great.
Faster cranks and no more fender solenoid issues.
Old 07-04-2014, 09:29 AM
dylansf23's Avatar
as far as the 11k gvwr im pretty certain its either a fat stack of short guys like my buds f-super duty(also a ten bolt axle) or has a nice set of helpers. waiting on a reply about the frame width, hopefully he didnt leave for work yet aha
Old 07-04-2014, 09:36 AM
pedant
What would you want to show me?
Email is enabled in my profile.
The utility body doesn't have a LS rear and it likely won't fit under your truck.
137" WB just doesn't seem right for a regular cab pickup.
Talk to Brad.
I'm sure he could set you straight on how these things came.
Old 07-04-2014, 09:37 AM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is offline
Diesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud of
4wd duallys were ONLY cab-n-chassis
Cab-n-chassis
The rear springs were only 2.5"
The frame behind the cab is only 34"
Wheel base is 137" and 161"
Pickups
rear springs are 3"
frame behind cab is 36"
wheel base is 133 and 164
Old 07-04-2014, 09:42 AM
dylansf23's Avatar
brads finally awake!
and he delivers bad news...aha
it seems odd that they would do different axle perches on the trucks, wouldnt it be easier to do different shackle mounts and use the same axles throughout the entire line up?
thanks guys!
EDIT: 4x4 duallys through what year? incase i find another, or did it change with the body style?
Old 07-04-2014, 10:12 AM
thanks guys!
They made 3 different rear axles.
1. SRW
2. DRW pickup
3. DRW cab-n-chassis
They did the 3 different axles for good reasons.
C-n-c frame is a industry standard @ 34" for the aftermarket body companies.
Then the axle is also narrower to keep the tires under the said bodies.
Axle perches are narrower to be able to fit the dual tires.
The 2.5" springs are used because the tire to frame space was minimal.
DRW pickup axles are the widest. they are 6" wider than a SRW axle.
They needed to do this because of the 36" frame with and the pickup 3" springs.
From 80-97 the ONLY way to get a 4wd dually from FORD was as a cab-n-chassis. If you have ever seen a 4wd dually pickup, it was converted.
Just like the one I built
Old 07-04-2014, 10:19 AM
dylansf23's Avatar
ahh okay
thanks for the info!
stupid nice looking trucks!! im super jealous!
Old 07-05-2014, 05:39 AM
dylansf23's Avatar
so i found a set of 06 f350 axles for way cheaper then just a dana 60 front 90k on them.
i know that is disc brake territory, which would mean id need a different proportioning valve since mine is a disc/drum. would i have to switch to hydroboost to get enough pressure for disk all the way around?
would i even be able to use them? perches and ujoint and such
Old 07-05-2014, 06:31 AM
pedant
I don't know anything about rear disc conversions or whether those perches might fit your frame.
Pressure shouldn't be an issue as much as volume, I would think.
U-joints shouldn't be any problem.
Ford used many conversion (b astard) U-joints over the years.
That word seems to hit the language filters, but that is what to ask for at a driveline shop.
Old 07-05-2014, 06:37 AM
dylansf23's Avatar
do you know who might?
ive heard some of the newer axles have a longer spline and would need a shorter dshaft
Old 07-05-2014, 06:48 AM
pedant
I'm sure Brad will chime in.
Having a drive shaft shortened is no big deal.
I had a new yoke welded on mine last year after I destroyed a U-joint.
Is it really that hard to find a year appropriate donor truck down there?
Why were you looking at duallys???
  #28
Old 07-05-2014, 06:56 AM
dylansf23's Avatar
i was looking at that dually because it would be a good truck after i stole the axles.
yes it is, the junkyards are terrible, once a truck goes there, they set them on axles in mud and bent the heck out of the brakes, forklift them around they become useless and are picked apart immediately.
im really looking for that f350 351 5speed, but i haven't seen one yet, not even for 5k+
im willing to travel, i dont mind, ive searched all of the east coast, but i either get a f350 or a manual, not both.
id be fine with newer axles and running an adapter since my tires currently rub on my leave springs up front, and im not sure a lift would fix that? ive been told to put it on jacks and test my left to right turn radius but i havent gotten around to it yet.
ive even got a buddy in michigan looking for me but no luck. id think they would be an old rusted plow truck or something ya know?
  #29
Old 07-05-2014, 07:43 AM
Lets see... Where to start
06 axle are coil spring front, so you would need coil springs, coil spring buckets, radius arms, radius arm mounts, track bar and some sort of track bar
06 rear axle. it is pretty much a direct bolt in with some new u-bolts. Then you need to adapt the 86 e-brake cables to the 06 axle.
The 99+ trucks use a metric 8 lug pattern 8 on 170mm. 05+ trucks use 17" wheels.
ALOT of work to use those axle
If you REALLY want a good donor truck, PM me. My brother has a 93/93 f350 PICKUP 460, 5speed, 4wd with a Meyers 8' plow he wants 3k for. And it is in pretty good shape. The bed is ROT FREE. He also has a ZF5 from a small block
  #30
Old 07-05-2014, 07:49 AM
dylansf23's Avatar
what about 2002 axles? are they coil sprung? i didnt know they went to coils that early. darn
pm sent brad
Solid axle swap and lift rowdyredneck 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 7 11-20-2016 03:04 PM
1/2 ton SAS (Solid Axle Swap) guide 9.ford.5 Offroad & 4x4 137 10-30-2015 01:54 AM
D60 SWITCH PlumCrazy7 1987 - 1996 F150 & Larger F-Series Trucks 14 04-04-2015 01:02 PM
F250 4x4 Front axle options - D60 SAS? 63nova86F250 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 0 03-29-2012 09:10 PM
Ford F250 TTB TO D60 SAS Questions nossliw Offroad & 4x4 12 11-30-2011 09:43 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
