Breather vent on a Ford 10.25" Differential?
Old 07-03-2014, 11:34 PM
MontanaMan's Avatar
MontanaMan
MontanaMan is offline
Hi:
- 1989 Ford F250
- Ford 10.25" rear axle with full floating hubs.
Is there a vent hole in the differential? I can't find anything that looks like that. There is a wire coming out of the top, but no vent tube. Am I missing something?
The reason I'm asking is because the pinion seal and one of the axle hub seals are leaking. I thought maybe the vent was blocked or something. But I can't even find a vent.
Help me out.
Thanks.
Old 07-04-2014, 06:51 AM
tjc transport's Avatar
tjc transport
tjc transport is offline
i ain't rite
Received 3,078 Likes on 2,148 Posts
the vent is where the soft brake line connects to the distribution block that the hard lines connect to that go to each wheel cylinder.
the center of the block is the vent, and then a hose connects to that and goes up to the frame to keep contaminates out.
Old 07-04-2014, 07:32 AM
LeoJr's Avatar
LeoJr
LeoJr is offline
What Tom said...and it's on the axle tube, driver's side, not in the center section itself.
roadrash63
10-30-2018 10:48 PM
BuckHammer
17
09-13-2012 01:41 PM
RabidJade
03-16-2011 06:56 PM
karljay
04-04-2002 08:58 PM
Quick Reply: Breather vent on a Ford 10.25" Differential?
