Transmission Fluid Temp Custom PID for TorquePro - Ford Truck Enthusiasts Forums
Old 07-03-2014, 11:21 PM
Mike8253 Mike8253 is offline
Mike8253 is starting off with a positive reputation.
I have a 37' 2004 motorhome on a F53 chassis with Ford 6.8L V-10. I've just downloaded the TorquePro app for my Android phone, and will receive my OBD2 Bluetooth transmitter on Saturday. I'll use this setup to augment the minimal gauges in the dash. I'm particularly interested to have transmission fluid temp displayed for monitoring particularly during long or steep hill climbs. In the Custom PID selector menu there are two choices for adding a trans temp custom PID, a "Transmission Fluid Temp (Method 1)" selection, and also a "Transmission Fluid Temp (Method 2)" selection. Is one more appropriate for my year V-10 and the other? The disclaimer in the app puts the fear of God in you to not select a wrong PID. Thanks.
Old 07-04-2014, 12:14 PM
I'm told now that the transmission fluid temp Custom PIDs provided in the Torque Pro app are for the 6.0L diesel. Has anyone found one for my year 6.8L V10? 2004, 2-valve. Thanks.
Old 07-04-2014, 02:18 PM
Vwags's Avatar
Vwags Vwags is offline
Vwags is a splendid one to beholdVwags is a splendid one to beholdVwags is a splendid one to beholdVwags is a splendid one to beholdVwags is a splendid one to beholdVwags is a splendid one to beholdVwags is a splendid one to beholdVwags is a splendid one to behold
Yes I added it in the extended PID's for Ford. I had tried letting it scan for the PID's and it didn't work.
Open Torque
Menu
Settings
Manage extra PIDs/Sensors
Menu
Add predefined set
Ford
Old 07-04-2014, 04:32 PM
Thanks for your reply. Which of the two PIDs do you use? Method 1 (OBD Header - Auto) or Method 2 (OBD Header - TCM)?
Old 07-05-2014, 01:37 AM
Vwags's Avatar
If I recall when I looked at all the available information either they both were reading the same or I picked the one that was reading. I don't remember but I will look tomorrow when I am driving it and see what is reading. I said reading a lot didn't I. I need a thesaurus.
Old 07-05-2014, 11:35 AM
Vwags's Avatar
Ok. I was driving the Sherpa and checked my app. The easiest way to know is when you long press to add a reading the complete list shows up and available shows green along with the data it is reading. Just pick what you want.
Old 07-06-2014, 03:37 PM
Received my Bluetooth transmitter yesterday and when to the MH today to connect up and see what I could get. Turns out that both of the Trans Fluid Temp PID's worked, so that's settled. I had also hoped that I could get engine oil temperature as well, but in this case, neither of the Ford Extended PID's s for oil temperature work. Any chance to read this parameter as well, or is it not available? Thanks.
7.3L PIDs for 2016 - Torque Pro and others. Tugly 1999 - 2003 7.3L Power Stroke Diesel 134 03-01-2017 02:50 AM
How to read Trans oil temp on 07 Explorer V8 using Torque app? Spades Explorer, Sport Trac, Mountaineer & Aviator 0 07-11-2016 11:48 AM
PID question DanielT28 1999 - 2003 7.3L Power Stroke Diesel 10 04-05-2016 09:53 AM
Custom PIDs for 2013 F150 5.0 cale10 2009 - 2014 F150 0 02-02-2016 01:34 AM
Torque Pro - PID for Engine Oil Temp BGLeRoy Modular V10 (6.8l) 2 05-01-2015 10:34 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
