Ignition starter interlock - Ford Truck Enthusiasts Forums
1968-2013 Full Size Vans Econolines. E150, E250, E350, E450 and E550
Old 07-03-2014, 09:38 PM
BobKittel BobKittel is offline
BobKittel is starting off with a positive reputation.
I have a E350 van 1993 automatic. Some weeks ago the shift tube and cover tube broke. I dropped the steering column and put new parts in. The truck shifts just fine now except that the ignition while going to on position will not actuate the starter. Did I unplug something, break something or leave something out? I don't seem to have any extra parts, this time. I can start the car by crossing the solenoid poles. All positions on the gear selector work but just can not find where start is or if it is in the ignition or shift rod somewhere.
Old 07-04-2014, 06:42 AM
JWA's Avatar
JWA JWA is offline
JWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputation
Assuming you used year-appropriate replacement parts its either the rod that pushes the sliding contact of the ignition switch is bent or otherwise not pushing the starter engage contact far enough.
It could also be the connector wiring to the sliding ignition switch is damaged---double check that.
More unlikely is the lock cylinder is the issue but your description doesn't suggest that.
Let us know what you find please---could be helpful to others down the road.
Old 07-04-2014, 08:31 AM
I have new parts from the Ford dealer so I know that everything was correct and not bent. The parts are an upgrade because of a design flaw in the old style which caused the rod and tube to break. JWA, I will look at the two items you mention. Thanks for the help.
Old 07-04-2014, 03:52 PM
VannerDude VannerDude is offline
VannerDude is starting off with a positive reputation.
Yes, please post a solution when you find one. Very unusual.
Old 07-05-2014, 07:08 PM
jimandnena jimandnena is offline
jimandnena is gaining momentum as a positive member of FTE.
Quote:
Hi Bob,
is the neutral switch connected and positioned correctly? I think that would prevent the starter from operating. You might try turning the key to start and slightly moving the shift lever. Make certain you have your foot on the brake pedal in case it should start in gear (voice of experience).
jim
Electrical Ignition Problems Delp73 1973 - 1979 F-100 & Larger F-Series Trucks 10 11-05-2016 08:43 AM
Need Help getting truck to run. davidrozeboom1 1973 - 1979 F-100 & Larger F-Series Trucks 9 07-28-2016 04:15 PM
1999 f150 starter is good but wont start. taylerallen6 1997 - 2003 F150 8 06-21-2016 07:45 PM
92 F150 E40D ignition key cylinder blocked/stuck wrooper 1987 - 1996 F150 & Larger F-Series Trucks 4 05-05-2016 07:57 PM
Ignition Lock to rack/pushrod timing tonkyman 1987 - 1996 F150 & Larger F-Series Trucks 11 07-02-2013 10:40 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
