Help ID my Truck - Ford Truck Enthusiasts Forums
Help ID my Truck
Old 07-03-2014, 07:43 PM
Tonzfseries's Avatar
Tonzfseries Tonzfseries is offline
Tonzfseries is starting off with a positive reputation.
Help ID my Truck
Hi Guys new to the site found it in a search for info on my (what i believe is) 1949 v8 F-? series truck. I really would like to ID it as I'm not sure what F it is from what i can gather so far maybe F4 or 5, The only numbers I can find is LH side rail just behind the bumper (7R8T 5014)& LH top of fire wall (7C or G81 1854) & RH in front of battery box (9G12878*). no plate on glove box lid. Ill post the pics any help would be gr8 Thanks Tony
Old 07-03-2014, 07:47 PM
Gicknordon's Avatar
Gicknordon Gicknordon is offline
Gicknordon is a name known to allGicknordon is a name known to allGicknordon is a name known to allGicknordon is a name known to allGicknordon is a name known to allGicknordon is a name known to all
I believe that would be an f-4. Does it have a single or double wall frame?
Old 07-03-2014, 08:07 PM
Thanks Nick , Yes it is double rail up to the front of the rear spring hanger
Old 07-03-2014, 08:10 PM
mtflat mtflat is offline
mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.
None of those numbers id the year. Single speed rear is F4 or 5, so what size wheels do you have?
Any vin no's on the firewall?
Old 07-03-2014, 08:17 PM
Gicknordon's Avatar
Quote:
If its double rail then it would be an f-5 if im not mistaken
Old 07-03-2014, 08:24 PM
single speed rear on 750-20" tyres
Old 07-03-2014, 08:35 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is offline
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
Being an Aussie truck, I wonder if it uses the Canadian system of serial numbers? Is it RHD?
BTW, welcome to the forum!
Old 07-03-2014, 08:42 PM
Doc's Avatar
Doc Doc is online now
Doc has much to be proud ofDoc has much to be proud ofDoc has much to be proud ofDoc has much to be proud ofDoc has much to be proud ofDoc has much to be proud ofDoc has much to be proud ofDoc has much to be proud of
Looks an awful lot like an F-5 to me. Welcome to the forum.
Old 07-03-2014, 09:02 PM
Harrier's Avatar
Harrier Harrier is online now
Harrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud of
We seem to have a good contingent of Aussies on this site now. That great.
Welcome to FTE!
What are your plans for it?
Old 07-03-2014, 09:23 PM
51dueller's Avatar
51dueller 51dueller is offline
51dueller has a great reputation on FTE.51dueller has a great reputation on FTE.51dueller has a great reputation on FTE.51dueller has a great reputation on FTE.
I can tell you the 7R8T means a 158" wheelbase for a F-4/5/6 truck.
It should have a Canadian vin number on the left side frame rail in the engine compartment and under the cab just after the transmission crossmember on the same side. I assume its also missing the tag plate on the top center of the firewall in the engine compartment.
There should also be a plate beside the starter solenoid on the right hand on the firewall. Can't quite remember what is exactly on this one but might help narrow it down.
Old 07-04-2014, 01:43 AM
That would be an F5 here in the states.
The Canada connection, hmmm - that front marker light does look like Mercury
Old 07-04-2014, 01:57 AM
aussiecowboy aussiecowboy is offline
aussiecowboy is gaining momentum as a positive member of FTE.aussiecowboy is gaining momentum as a positive member of FTE.
Looks like a really nice solid truck.
Old 07-04-2014, 05:05 AM
Thanks for the welcome guys
It is a solid truck very little rust to good to pass up.
Yes Ross it is RH drive & unfortunately Nathan it is missing all the tags, i have had a wire brush on the left hand rail but found nothing.The cab is coming off so i will be looking for the number under the cab. Only thing as in parts so far on the list , not that i have look hard yet is a left hand outside door handle, right hand bonnet hinge, the plastic grill centre of dash, rubber kit, dash switchers & brake lines under g/box are rusted but I'm sure that list will get longer as it get broken down.
Old 07-04-2014, 05:21 AM
Everything you have listed there can be bought new mate, I bought all the same parts plus a heap more for my F3. Feel free to email me at aussiecowboy@gmail.com. I still have quite a few bits floating around. Bring the parts in direct from the states, DO NOT buy in Aus unless you're willing to mortgage your house!
Old 07-04-2014, 05:36 AM
Quote:
Welcome to FTE!
Good Question Joe. The big picture is a full restore. Just haven't worked out all the bits in between. Im looking at some sort of small tilt tray for bikes and vintage tractor. A long story short is I have a small tilt tray towing business and move old bikes, cars, machinery, etc to shows and would like my transport truck to be a part of them.Love my Fords always had Fords so instead of restoring a ford car I thought a truck is something different and useful to complement what i do. At this point I would like to keep it stock all but the engine and box . I have a nice 351 windsor and auto but with the auto I would like to do something with the brakes. Not quiet shore about diff yet or ratios , Im leaving it all a bit open at this point till iI learn more about them see what others have done to improve and so on.
Local spring show theodore/teddy 1948 - 1956 F1, F100 & Larger F-Series Trucks 9 05-09-2016 08:14 PM
Teddy's new Interior and tunes theodore/teddy 1957 - 1960 F100 & Larger F-Series Trucks 14 04-20-2016 04:55 PM
I think I'm done for now? nieto1124 Excursion - King of SUVs 20 03-31-2015 12:04 AM
Finally came!! Pics of my 1950 Ford F2 DocRoche 1948 - 1956 F1, F100 & Larger F-Series Trucks 25 03-04-2015 08:37 PM
Mesquite Motor mania pic's theodore/teddy 1948 - 1956 F1, F100 & Larger F-Series Trucks 5 01-18-2015 08:45 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
