Help ID my Truck
Old 07-03-2014, 06:43 PM
Tonzfseries's Avatar
Tonzfseries
Tonzfseries is offline
Help ID my Truck
Hi Guys new to the site found it in a search for info on my (what i believe is) 1949 v8 F-? series truck. I really would like to ID it as I'm not sure what F it is from what i can gather so far maybe F4 or 5, The only numbers I can find is LH side rail just behind the bumper (7R8T 5014)& LH top of fire wall (7C or G81 1854) & RH in front of battery box (9G12878*). no plate on glove box lid. Ill post the pics any help would be gr8 Thanks Tony
Old 07-03-2014, 06:47 PM
Gicknordon's Avatar
Gicknordon
Gicknordon is offline
I believe that would be an f-4. Does it have a single or double wall frame?
Old 07-03-2014, 07:07 PM
Tonzfseries
Thanks Nick , Yes it is double rail up to the front of the rear spring hanger
Old 07-03-2014, 07:10 PM
mtflat's Avatar
mtflat
mtflat is offline
None of those numbers id the year. Single speed rear is F4 or 5, so what size wheels do you have?
Any vin no's on the firewall?
Old 07-03-2014, 07:17 PM
Gicknordon's Avatar
Gicknordon
If its double rail then it would be an f-5 if im not mistaken
Old 07-03-2014, 07:24 PM
Tonzfseries
single speed rear on 750-20" tyres
Old 07-03-2014, 07:35 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is offline
Being an Aussie truck, I wonder if it uses the Canadian system of serial numbers? Is it RHD?
BTW, welcome to the forum!
Old 07-03-2014, 07:42 PM
Doc's Avatar
Doc
Doc is online now
Looks an awful lot like an F-5 to me. Welcome to the forum.
Old 07-03-2014, 08:02 PM
Harrier's Avatar
Harrier
Harrier is online now
We seem to have a good contingent of Aussies on this site now. That great.
Welcome to FTE!
What are your plans for it?
Old 07-03-2014, 08:23 PM
51dueller's Avatar
51dueller
51dueller is offline
I can tell you the 7R8T means a 158" wheelbase for a F-4/5/6 truck.
It should have a Canadian vin number on the left side frame rail in the engine compartment and under the cab just after the transmission crossmember on the same side. I assume its also missing the tag plate on the top center of the firewall in the engine compartment.
There should also be a plate beside the starter solenoid on the right hand on the firewall. Can't quite remember what is exactly on this one but might help narrow it down.
Old 07-04-2014, 12:43 AM
mtflat's Avatar
mtflat
mtflat is offline
That would be an F5 here in the states.
The Canada connection, hmmm - that front marker light does look like Mercury
Old 07-04-2014, 12:57 AM
aussiecowboy's Avatar
aussiecowboy
aussiecowboy is offline
Looks like a really nice solid truck.
Old 07-04-2014, 04:05 AM
Tonzfseries
Thanks for the welcome guys
It is a solid truck very little rust to good to pass up.
Yes Ross it is RH drive & unfortunately Nathan it is missing all the tags, i have had a wire brush on the left hand rail but found nothing.The cab is coming off so i will be looking for the number under the cab. Only thing as in parts so far on the list , not that i have look hard yet is a left hand outside door handle, right hand bonnet hinge, the plastic grill centre of dash, rubber kit, dash switchers & brake lines under g/box are rusted but I'm sure that list will get longer as it get broken down.
Old 07-04-2014, 04:21 AM
aussiecowboy
Everything you have listed there can be bought new mate, I bought all the same parts plus a heap more for my F3. Feel free to email me at aussiecowboy@gmail.com. I still have quite a few bits floating around. Bring the parts in direct from the states, DO NOT buy in Aus unless you're willing to mortgage your house!
Old 07-04-2014, 04:36 AM
Tonzfseries
Welcome to FTE!
Good Question Joe. The big picture is a full restore. Just haven't worked out all the bits in between. Im looking at some sort of small tilt tray for bikes and vintage tractor. A long story short is I have a small tilt tray towing business and move old bikes, cars, machinery, etc to shows and would like my transport truck to be a part of them.Love my Fords always had Fords so instead of restoring a ford car I thought a truck is something different and useful to complement what i do. At this point I would like to keep it stock all but the engine and box . I have a nice 351 windsor and auto but with the auto I would like to do something with the brakes. Not quiet shore about diff yet or ratios , Im leaving it all a bit open at this point till iI learn more about them see what others have done to improve and so on.
Quick Reply: Help ID my Truck
