1999 f250 5.4 no spark - Ford Truck Enthusiasts Forums
Old 07-03-2014, 01:16 PM
Himboot Himboot is offline
Himboot is starting off with a positive reputation.
Just got the truck starts when cold once driven for an hour or so it wouldnt start wait an hour starts did that for 3 weeks now wont start at all I changed crank sensor still no spark when i did crank sensor noticed wirers where cut and plug must of been replaced if its not crank sensor where do i go next plz help
Old 07-06-2014, 09:10 PM
carguy94 carguy94 is offline
carguy94 is starting off with a positive reputation.
how did you verify the no spark at a spark plug or coil. how did you find that the crank sensor was at fault did you test more than one coil. how fast doe the engine crank and get any codes pulled from the truck.
Old 07-06-2014, 09:24 PM
Bigpipes 35's Avatar
Bigpipes 35 Bigpipes 35 is offline
Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.
My next move would be the cam sensor,,,
Old 07-07-2014, 08:14 AM
projectSHO89 projectSHO89 is offline
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
A cam sensor will not cause a "no spark" condition. At worse, it will cause multiple starting attempts as the PCM guesses at injector timing in the absence of a valid cam signal.
Old 07-07-2014, 09:10 AM
Quote:
True but he hasn't told us yet how he has determined he has no spark,,,
Old 07-07-2014, 12:17 PM
Since a cam sensor won't cause a solid "no start" anyway, it doesn't much matter.
Old 07-07-2014, 12:21 PM
After rereading his original post I would check fuel pressure next since you don't think it is cam related. Still don't have an answer on how he determined he has no spark..
04 Escape HELP kevinmpd02 2004 - 2008 F150 2 03-17-2016 04:10 PM
03 f150 5.4L won't start Sk8rzch Modular V8 (4.6L, 5.4L) 1 11-10-2015 06:59 AM
1999 Ranger 4.0 Cranks but won't Start Fred Furrer Ranger & B-Series 30 09-08-2015 10:08 PM
1996 EXP cranks but will not start steve(ill) Explorer, Sport Trac, Mountaineer & Aviator 8 08-04-2015 06:24 PM
2006 Escape hard to start. rlester Escape & Escape Hybrid 1 03-07-2015 11:34 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
