1999 f250 5.4 no spark
Old 07-03-2014, 12:16 PM
Himboot's Avatar
Himboot
Himboot is offline
Just got the truck starts when cold once driven for an hour or so it wouldnt start wait an hour starts did that for 3 weeks now wont start at all I changed crank sensor still no spark when i did crank sensor noticed wirers where cut and plug must of been replaced if its not crank sensor where do i go next plz help
Old 07-06-2014, 08:10 PM
carguy94's Avatar
carguy94
carguy94 is offline
how did you verify the no spark at a spark plug or coil. how did you find that the crank sensor was at fault did you test more than one coil. how fast doe the engine crank and get any codes pulled from the truck.
Old 07-06-2014, 08:24 PM
Bigpipes 35's Avatar
Bigpipes 35
Bigpipes 35 is offline
My next move would be the cam sensor,,,
Old 07-07-2014, 07:14 AM
projectSHO89's Avatar
projectSHO89
projectSHO89 is online now
A cam sensor will not cause a "no spark" condition. At worse, it will cause multiple starting attempts as the PCM guesses at injector timing in the absence of a valid cam signal.
Old 07-07-2014, 08:10 AM
Bigpipes 35
True but he hasn't told us yet how he has determined he has no spark,,,
Old 07-07-2014, 11:17 AM
projectSHO89
Since a cam sensor won't cause a solid "no start" anyway, it doesn't much matter.
Old 07-07-2014, 11:21 AM
Bigpipes 35
After rereading his original post I would check fuel pressure next since you don't think it is cam related. Still don't have an answer on how he determined he has no spark..
Old 09-27-2019, 10:32 PM
hondabuju's Avatar
hondabuju
hondabuju is offline
Im having this same issue..Need your help plz..
jasonmesq
1997 - 2003 F150
39
02-23-2022 01:31 PM
sontours
1999 to 2016 Super Duty
02-16-2013 08:21 PM
Moore558
3.8 & 4.2L V6
03-29-2012 09:44 PM
976dave
1997-2006 Expedition & Navigator
01-31-2010 12:25 PM
Dorzok
1983 - 2012 Ranger & B-Series
05-13-2008 03:35 PM
Quick Reply: 1999 f250 5.4 no spark
