1989 E350 7.3 idi. blue smoke ay hwy speed - Ford Truck Enthusiasts Forums
1968-2013 Full Size Vans Econolines. E150, E250, E350, E450 and E550
Old 07-03-2014, 10:13 AM
stockcar1974's Avatar
stockcar1974 stockcar1974 is offline
stockcar1974 is starting off with a positive reputation.
I have a 1989 E350 with a 7.3. At hwy speeds (55 or higher) I get blue smoke coming out the tail pipe. It will do it for a few minutes then clear up for a few minutes. I'm thinking valve guide seals, but don't know these diesels to well. Any body out there have any ideas?
Old 07-03-2014, 12:32 PM
Gettysburg150's Avatar
Gettysburg150 Gettysburg150 is offline
Gettysburg150 is gaining momentum as a positive member of FTE.Gettysburg150 is gaining momentum as a positive member of FTE.
Id check over in the pre-powerstroke forum on this site. Lots of IDI knowledge there.
Yes it could be valve seals, depends how bad its smoking and under what conditions. I know they start to smoke when injectors or pumps start to **** the bed
E-350 van Transmission leaking fluid out top jrollinssr 1968-2013 Full Size Vans 6 07-21-2015 10:50 PM
Need help on 99.5 7.3 Powerstroke Steven7.3 1999 - 2003 7.3L Power Stroke Diesel 15 09-09-2014 10:32 PM
studdering idle and worse when coming to a stop bestrada11 1999 - 2003 7.3L Power Stroke Diesel 2 08-16-2014 03:10 AM
86 E-350 RV with 460 popping and stalling at hwy speed Dizzy daddy General Automotive Discussion 1 04-13-2014 03:07 PM
e250 vs e350 cutaway fuel mileage 92 custom305 1968-2013 Full Size Vans 2 01-06-2012 07:44 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
