Modular V10 (6.8l)
Stuck in Durango-Blown Transmission
Old 07-07-2014, 08:16 AM
truckfella's Avatar
truckfella
truckfella is offline
Originally Posted by Mark Kovalsky
You can go up to 220F all day long with no problems. You can go as high as 250F for no more than a half hour at a time.
Mark, are these temps/times true for both the 4R100 and the 5R110?
Old 07-11-2014, 01:03 PM
JD'sBigredv10's Avatar
JD'sBigredv10
JD'sBigredv10 is offline
New transmission was installed Wednesday afternoon and we hit the road within a couple hours. The final price was actually 10% less than the initial estimate. That was a small yet satisfying surprise. Made it home yesterday about 21 hours after we left Durango only taking a five hour nap in the Kingman, AZ Walmart parking lot. New tranny performed flawlessly but about 75 miles from home, the A/C started acting funny. When in the A/C Max position, air would periodically stop blowing through the dash vents and start blowing through the defrost vents. After playing around with the dials some, it eventually worked okay in the standard A/C position. What is going on?
Old 07-11-2014, 03:15 PM
projectSHO89's Avatar
projectSHO89
projectSHO89 is offline
Mild vacuum leak.
Old 08-15-2015, 04:47 PM
Jaime74656's Avatar
Jaime74656
Jaime74656 is offline
You have a mild vac leak some where most likely a line is broken or in plugged (going to say more like cracked) and it is allowing air in
Old 08-15-2015, 08:46 PM
projectSHO89
I told him that he had a vacuum leak 5 weeks ago.
Old 08-16-2015, 08:39 AM
Hank85713's Avatar
Hank85713
Hank85713 is offline
did you get the SG? Autozone sells them as does camp world. I think AZ is a little cheaper.
MMMMGas
1999 to 2016 Super Duty
16
05-26-2022 12:06 PM
Spool&Go
08-08-2016 12:35 PM
mason55
08-12-2015 10:17 PM
KenRebF-250
19
03-15-2013 11:12 AM
rackhound
18
07-07-2011 12:07 PM
Quick Reply: Stuck in Durango-Blown Transmission
