Stuck in Durango-Blown Transmission - Page 2 - Ford Truck Enthusiasts Forums
Old 07-07-2014, 08:16 AM
truckfella's Avatar
truckfella truckfella is offline
truckfella has a good reputation on FTE.truckfella has a good reputation on FTE.
Quote:
Originally Posted by Mark Kovalsky View Post
You can go up to 220F all day long with no problems. You can go as high as 250F for no more than a half hour at a time.
Mark, are these temps/times true for both the 4R100 and the 5R110?
Old 07-11-2014, 01:03 PM
JD'sBigredv10 JD'sBigredv10 is offline
JD'sBigredv10 is starting off with a positive reputation.
New transmission was installed Wednesday afternoon and we hit the road within a couple hours. The final price was actually 10% less than the initial estimate. That was a small yet satisfying surprise. Made it home yesterday about 21 hours after we left Durango only taking a five hour nap in the Kingman, AZ Walmart parking lot. New tranny performed flawlessly but about 75 miles from home, the A/C started acting funny. When in the A/C Max position, air would periodically stop blowing through the dash vents and start blowing through the defrost vents. After playing around with the dials some, it eventually worked okay in the standard A/C position. What is going on?
Old 07-11-2014, 03:15 PM
projectSHO89 projectSHO89 is online now
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
Mild vacuum leak.
Old 08-15-2015, 04:47 PM
Jaime74656's Avatar
Jaime74656 Jaime74656 is online now
Jim
Jaime74656 has a great reputation on FTE.Jaime74656 has a great reputation on FTE.Jaime74656 has a great reputation on FTE.Jaime74656 has a great reputation on FTE.Jaime74656 has a great reputation on FTE.Jaime74656 has a great reputation on FTE.
Quote:
You have a mild vac leak some where most likely a line is broken or in plugged (going to say more like cracked) and it is allowing air in
Old 08-15-2015, 08:46 PM
I told him that he had a vacuum leak 5 weeks ago.
Old 08-16-2015, 08:39 AM
Hank85713 Hank85713 is offline
Hank85713 is gaining momentum as a positive member of FTE.
did you get the SG? Autozone sells them as does camp world. I think AZ is a little cheaper.
Considering an Excursion-Talk me in/out of it? karrun Excursion - King of SUVs 164 03-20-2017 10:17 PM
HPOP? How long do I Have? tnewb33 Excursion - King of SUVs 11 08-06-2016 09:59 AM
Transmission "belched" a little fluid mason55 1999 - 2003 7.3L Power Stroke Diesel 6 08-12-2015 10:17 PM
Long time lurker JD'sBigredv10 Modular V10 (6.8l) 14 05-14-2014 12:16 PM
Triton V-10 Towing Report Wolfboro Modular V10 (6.8l) 4 10-11-2011 07:10 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
