300 I6 Rebuild Info Needed - Ford Truck Enthusiasts Forums
Old 07-02-2014, 10:20 PM
Jonesy1981 Jonesy1981 is offline
Jonesy1981 is starting off with a positive reputation.
I have a 300 I6 guessing that it is a 1985. Not very positive the motor mounts; I purchased will not line up. The Bronco is 1985. How do I find out the year of the block by looking at the stamp on the block? I'm thinking of 're-building it next year . It's basically a weekend driver. I have heard of pulling around 300+ hp out of one and I think it would be pretty cool. I have looked at alot of threads but I need to know how to go about doing it. How to choose the right pistons, mild cam, what to do about the head, rods , etc. There is no-one around here that will do it so I'm gonna attempt to do it myself😯 I have also looked at crate motors also. Idk Any info will be greatly appreciated
Old 07-03-2014, 02:10 PM
Conanski's Avatar
Conanski Conanski is offline
Conanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud of
The BIG problem with the 300 is the cylinder head and you will never get even close to 300hp without a much bigger head or with forced induction and a heavily ported stock head.
The block casting number will tell you what vintage casting you have, it won't tell you the exact year the engine was built but that's not really important anyway. Casting numbers can be decoded by following the link at the top of this forum.
I have a lot of questions about building a truck F250/350 juddspaintballs 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 7 09-01-2016 11:18 PM
Motor mounts 1985 f250 roadrash63 Ford Inline Six, 200, 250, 4.9L / 300 3 12-29-2015 02:58 PM
Supercharger on a 300-6 wildjon300ci Ford Inline Six, 200, 250, 4.9L / 300 22 07-23-2015 01:45 PM
73 F250 Coolant in the oil 360 what to do? decaruby FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 1 05-24-2015 11:50 AM
built motor and distributor problem dylansf23 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 17 03-30-2014 01:37 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
