vibration under acceleration
Old 07-02-2014, 07:16 PM
andres0517's Avatar
andres0517
andres0517 is offline
My truck shakes under acceleration but as soon as I let off the pedal the vibration goes away. I checked my brakes but they are new, u-joints are also new. I had a shop rebuild m y front differential and drive shaft a few months ago. Could a bad tire do this? I h ave a 6 inch lift and 325 tires. Any help is appreciated.
Old 07-02-2014, 07:26 PM
Jmatthews's Avatar
Jmatthews
Jmatthews is offline
is a BAAAD MAN
You could rotate the tires to see if the vibration moves, and take out the driveshaft and drive in 4x4 to eliminate rear driveshaft issues. Do you have a long bed with a center carrier bearing?
Old 07-02-2014, 07:47 PM
andres0517's Avatar
andres0517
I did. And im not sure if the rotation moved. But the vibration is worse. To the point were I dont want to drive it. It is a short bed.. ill try to take out the driveshaft next.
Old 07-02-2014, 08:40 PM
Tugly's Avatar
Tugly
Tugly is offline
Is there any whining from under the truck... or in front? Is the vibration in the wheel or in your seat? Is it there if you let off the throttle at 65 MPH and hit the OD button? Is the vibration forward and backward, or side-to-side? What happens in a hard left turn or hard right turn? What made the vibration get worse?
Old 07-03-2014, 07:36 AM
Reckless's Avatar
Reckless
Reckless is offline
I just had the same thing where I had vibration under load in the 35-45mph range, but if I let off the gas it went away. Plus a little clunk when putting in forward gear. Turned out to be the rear driveshaft universal joint at the rear differential was toast. Changed both ends of the shaft (short wheel base no carrier bearing) greased the splines under the bootie and no more noise or clunk.
BTW, there was no noticeable slop in the shaft from underneath by hand in neutral which threw me off a little at the beginning and started me thinking too complicated.
Old 07-03-2014, 05:56 PM
andres0517's Avatar
andres0517
Honestly I dont even know whe the vibration is coming from. I feel it everywhere. When I make a hard turn it feels like is going to fall apart. Last summer I replace the driveshaft ujoints and the joke that comes from the differential. As soon as I let the pedal go everything gets smooth. I work all day today, but ill check the joint on the driveshaft tomorrow, maybe is loose? I hope so. Ill let you guys know what I find out
Old 07-03-2014, 07:07 PM
andres0517's Avatar
andres0517
Also it has a clunck when I put it in drive. Never did it before. How can I know if its the driveshaft.
Old 07-03-2014, 07:23 PM
Firefighter 1406's Avatar
Firefighter 1406
Firefighter 1406 is offline
Clunk when you put it into drive is either driveshaft u joints or the spline on your drive shaft needs greased.
Old 07-03-2014, 07:40 PM
Pitcrw6's Avatar
Pitcrw6
Pitcrw6 is offline
Could the shop put the drive shaft in a different position as in they forgot to put a chalk mark on it so it goes back the way it came out and now its worn out the u-joints and under load it vibrates?
Old 07-03-2014, 09:15 PM
andres0517's Avatar
andres0517
I did the job myself and marked everything. Its been fine for the past year. Ill probably have to take it the shop. Unless I can find whats wrong tomorrow.
Old 07-03-2014, 10:14 PM
KJNDIVER's Avatar
KJNDIVER
KJNDIVER is offline
Clunk when put in gear, vibration under acceleration, goes away when coasting...... dollars to donuts its a u-joint....
Old 07-04-2014, 07:00 AM
Pitcrw6's Avatar
Pitcrw6
Pitcrw6 is offline
^^^^^^^^^^^^X2
Old 04-20-2020, 11:39 AM
05XCRSN's Avatar
05XCRSN
05XCRSN is offline
Same issue
I can't get any play by hand but the wheels are still on the ground.
Thanks for posting, I'll try this first.
Dave042
2009 - 2014 F150
36
02-04-2019 05:44 PM
robert chavis
05-05-2011 06:21 AM
fastgnat
02-09-2011 09:27 AM
blackkawi400
08-13-2010 09:32 AM
Jawbreaker
1999 to 2016 Super Duty
25
06-25-2005 06:45 AM
Quick Reply: vibration under acceleration
