Steering Box F-600 or Toyota?
The steering box on my stock '56 is leaking pretty badly. This would be the third time in 21 years that it's had to come out.
What is the best option for a steering box if one intends to keep manual steering?
I did hear that an F-600 box would fit and are better/stronger in every way.
Is that right? They must be pretty rare too....
Or do we just go Toyota?
I am going another route with my 55, my son inlaw just picked up a crown vic front suspension for his 63. His recirculating ball steering on his 63 f100 is excellent, I'm going to swap that in. Its not a 100% bolt in but its close enough to make it a good swap I think. I have searched around but it looks like I will have to figure out the details myself.
The Toyota power or manual box are recirculating ball design, wich means they have minimal wear points making them very durable. changing from the stock box means you'll loose the steering wheel horn button unless you install the conversion kit Mid Fifty sells. Latest info update on the Toyota box is the manual and power box can both use the same conversion pitman arm.
I have a complete 56 custom cab (with built in turn signals) floor shift steering column and box I'm willing to part with. It has some play, but I have not tried adjusting it, I swapped in a Toyota PS box and tilt column. PM me for info if interested.
As it happens I was lucky to be able to locate a 1980 4x4 Toyota manual box.
I guess I'll use Mid-Fifty for the pitman arm etc. Has anyone used the manual box? Impressions?
I think the steering ratio is considerably faster on the Toyota box- would this affect the steering effort (harder) ?
While I am not entirely opposed to power steering, on the old truck, my thought was originally that I don't really mind the high steering effort that they exhibit, and the conversion would be cheaper and less complex (slightly).
After all I have 4 other vehicles, all power assisted everything, and I can't really remember ever really finding the stock steering to be so hard that I just HAD to go power.
As I mention above , I do have a source for a manual Toy box, but am worried that due to the faster ratio, that the effort will be even HIGHER.
That scenario is one I do wish to avoid.
I have searched around the net, but find no reports of a manual Toy conversion and how the steering compared to stock. Anyone reading this have experence with this?
driver96er
02-28-2008 08:54 PM
59flatbedford
04-11-2007 07:30 PM
buckethead5k
05-06-2006 11:44 PM
