spark plugs - Ford Truck Enthusiasts Forums
spark plugs
Old 07-02-2014, 05:30 PM
ramhunter5877 ramhunter5877 is offline
ramhunter5877 is starting off with a positive reputation.
spark plugs
what is the best spark plug for my 06 f150 5.4 ? is there any trick to getting them out ? thanks for any help.
Old 07-03-2014, 01:43 PM
gijim2k1's Avatar
gijim2k1 gijim2k1 is offline
gijim2k1 is starting off with a positive reputation.
Old 07-03-2014, 02:17 PM
cb_13's Avatar
cb_13 cb_13 is online now
cb_13 has a good reputation on FTE.cb_13 has a good reputation on FTE.cb_13 has a good reputation on FTE.
Motorcraft seem to work the best. I have had the best luck taking them out with the engine warm using a 3/8 impact.
Old 07-03-2014, 02:33 PM
jas88's Avatar
jas88 jas88 is offline
jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.
A 3/8" impact? Really? If you read the Ford TSB, it would seem that using an impact would be really bad. Not saying you are wrong, just saying it doesn't jibe at all with the Ford-recommended procedure for removing the plugs.
Old 07-03-2014, 02:50 PM
cb_13's Avatar
Quote:
Really. That's what worked best for me. Just don't put them back in with an impact lol. I worked at a dealer for 10 years. When one guy finds a successfull shortcut most everyone started using it. Picked that one up from a few guys I went to a driveability class with and I always broke less plugs with an impact, personally. Results may vary though.
Old 07-04-2014, 11:16 AM
TransWorxs TransWorxs is offline
TransWorxs is starting off with a positive reputation.
I always use Motor craft on my truck and my customers trucks also. Same with coils I've had bad luck with aftermarket coils.
Old 07-06-2014, 03:46 PM
Arby Arby is offline
Arby is starting off with a positive reputation.
I have almost 40k miles on the Champions. I know they won't be a pain to get out when I change them. The truck has run fine with them in.
Old 07-20-2014, 07:52 PM
spark plugs
just did my plugs took my time ,only broke one . I don't know how the truck ran they ware the worst plugs I ever seen. truck runs great now. thanks for your help .
engine not firing zech Ranger & B-Series 1 09-18-2015 10:25 AM
Just ejected spark plug wbnethery3 1997 - 2003 F150 17 10-22-2014 08:09 AM
Triton 5.4L Spark Plug Removal makthenif 1997 - 2003 F150 4 03-09-2014 05:18 PM
Bosch Platinum +4 Spark Plugs-Any Good? DictatorDanny General Automotive Discussion 20 02-09-2005 11:20 PM
390 spark plug question FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 2 07-11-2001 05:55 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
