Ground clearances: 2005 v10 4x4 - Ford Truck Enthusiasts Forums
Old 07-02-2014, 02:28 PM
sgc2c sgc2c is offline
sgc2c is starting off with a positive reputation.
I'm told the 4x4 Excursions ride a bit higher than the RWDs.
Is that true? I'm interested in an
05 6.8 v10. Do the diesels ride any higher than the gases?
I need a BIG vehicle that can drive through an occasional
deep puddle here in South Florida. I travel in miserable heavy rains on the 95 several times per year (bad ponding).
Does the 05 4x4 6.8 fit the bill?
How does it compare to say, a 2008 Cadillac Escalade ESV
awd in that and other aspects?
What are the respective ground clearances?
Old 07-04-2014, 11:58 AM
So which rides higher ?
Old 07-04-2014, 02:26 PM
wpnaes's Avatar
wpnaes wpnaes is online now
FTE SoCal Chapter LDR
wpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputation
Yes, the 4x4 s ride a bit higher- I recall 2 inches, but don't quote me on that. Specifications are here, I doubt ride height changed much across the years nor with engine type give an inch or two.
I'd get the 4x4 if you're concerned with getting stuck in the sand (I assume you mean off the pavement, if not any rice burner with decent tires will do driving through puddles on the pavement; yes, even on the 95). The V10 or V8 (we call 'em gassers) will be a fair amount cheaper than the smokers. The caddy will crash and burn the second you take it off the pavement.
Take pic and share them here when you buy the King of the SUVs.
Old 07-04-2014, 02:40 PM
No interest in sand driving.
On the 95, even in my 05 Lincoln Town Car, I've had real problems with ponding, and you can't go through deep puddles without sucking water through the air intake. Though the Lincoln is higher than many sedans.
I want something high off the ground so I can fearlessly go through deep water on roads, nowhere else.
One night on the 95, it was raining hard and I was essentially blown left into the next lane in the wake a a large 18 wheeler kicking up a ton of spray. The left lane had huge puddles and I hit it like a ton of bricks. After that I decided I wanted a vehicle that could both take the water and not be bullied and pushed around so easily. The Excursion looks like just what I need.
Anyone disagree?
Old 07-04-2014, 03:02 PM
wpnaes's Avatar
If you're hydroplaning with good tires up front on a heavy car, maybe just slow down or avoid the puddle? Wonder if you could make a snorkel for the Lincoln?
Regardless, get the excursion!
Old 07-04-2014, 03:09 PM
I was within the speed limit and was pushed into the puddle by the wake of a large truck.
I want a heavier vehicle so people can't do that to me.
Newby from South Florida racen83 New Member Introductions 0 03-27-2015 02:18 PM
1998 E350 w/ the 6.8 V10 automatic t flyboyaviator Clutch, Transmission, Differential, Axle & Transfer Case 2 01-29-2015 11:41 PM
Good shop in South West Florida EMC V10 X 6.0L Power Stroke Diesel 1 11-26-2014 08:45 PM
Florida Tire Recomendation EMC V10 X 1999 to 2016 Super Duty 4 11-14-2014 08:13 PM
How long to swap a M5OD / M5R2? dougjohnson72 1987 - 1996 F150 & Larger F-Series Trucks 4 11-13-2014 12:09 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
