CV Axle Boot Replacement - Ford Truck Enthusiasts Forums
Old 07-02-2014, 12:08 PM
73fan's Avatar
73fan 73fan is offline
73fan has a good reputation on FTE.73fan has a good reputation on FTE.
Hi folks,
1998 F-250LD 44
The outer boot is cracked, so I got a new one. Took the axle off, but cannot understand how to remove the boot. Where do I take the joint apart, any ideas?
Sent from Nexus 4. IB AutoGroup
Old 07-03-2014, 08:33 AM
kenn_chan kenn_chan is offline
kenn_chan is starting off with a positive reputation.
try to make this as short as possible, pull the shaft, cut the boot free, find a large (I mean large vice) rent a cv break apart tool a(looks like a slide hammer with an attachment to grab the end of the shaft, lock the shaft in the vice, and pop the end off. thoroughly and I mean completely clean all grease and crap out of the cv joint. use kerosene, brake parts cleaner whatever but clean it out totally. you have to get all grit sand dirt and old grease out of it. repack it taking your time to get grease back into all of the bearings.
insert cv knuckle into vice with the hole for the shaft end facing upwards, grab it firmly but knot enough to mar the splines. (use a piece of cardboard to protect them).
Slide boot and clamps over the shaft, insert end of shaft into the hole and press down until you hit the retaining clip, while applying pressure use a flat tipped screwdriver to work the clip into the bevel on the hole.
Once you have the clip started into the beveled edge of the hole use a dead blow hammer or a large chunk of 4x4 to smack the end of the shaft driving it home into the hole.
pack the boot lightly with the balance of the grease, slide the boot down onto the cv joint. "burp" the joint to remove excess air.
depending upon the type of clamp that came with the boot, you will either fold it over and use a punch and hammer to close the clamp or use a set of needle nose pliers to wind the clamp down before setting the clamp with the aforementioned punch and hammer.
check to make sure all dimensions are correct (boot location) and install the shaft.
Old 07-09-2014, 09:17 PM
Austin J.'s Avatar
Austin J. Austin J. is offline
Austin J. is gaining momentum as a positive member of FTE.
I would just return the boot and buy a new shaft. It is a lot less work, plus you have a temporary backup if you break one while wheeling or working.
1964 F250 4X4 SHIFTER BOOTS Cactusjack01 1961 - 1966 F-100 & Larger F-Series Trucks 4 07-11-2016 08:32 PM
Rear CV Boot bunky383 2007 - 2014 Expedition & Navigator 9 12-08-2013 02:22 PM
Intercooler Boots golfmedik 6.4L Power Stroke Diesel 4 02-28-2013 12:22 AM
2002 Escape drive shaft boot jtkk Escape & Escape Hybrid 16 07-06-2011 12:21 PM
Different CV boots Munch 1997 - 2003 F150 8 06-08-2009 05:02 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
