Full hydro help! - Ford Truck Enthusiasts Forums
Full hydro help!
Old 07-02-2014, 12:35 AM
rollinblackcloud rollinblackcloud is offline
rollinblackcloud is starting off with a positive reputation.
Full hydro help!
Hey guys, i need some technical help. 94 f250 7.3 powerstroke. Im turning 46s, and i wanna do full hydro. Not assist. This is a straight wheeling truck, no street.
First, For the orbital valve,, control valve..
What model, or size, or cc, or ci? Should i be using? And ive heard an 8" stroke ram is the norm? Any differences in rams besides lengths? Whats the stock output of my ps pump? Will i have to upgrade? Im 4 linked, front and rear. triangle top, 16" coilover. Huge lift. But im going to wheel it the most i can.
I dont care how many rotations of the steering wheel to actual wheel turn it is,
Just basicly need to know whats the best and most common set up and prefferable the cheapest lol. What should i buy? And part numbers please.
Old 07-04-2014, 12:48 AM
totalloser totalloser is offline
totalloser is starting off with a positive reputation.
Stock power steering pumps are relatively low flow, and low pressure. Pretty much any orbital should work fine. Displacement differential in a conventional cylinder may be worth a thought. Different displacement and force due to the volume lost on the rod side. There are balanced displacement rams specifically for steering applications that eliminate this issue basically by having a rod extend both sides. Or uses two cylinders facing in opposite directions.
With larger cylinders if this issue is not addressed you will need to worry about reservoir capacity as well since one side is a different displacement and will over flow the reservoir going one way and run dry going the other.
I would worry more about converting fittings. I like to swap everything to nptf since hardware store fittings still connect, but for a one off JIC is very nice. Another advantage of going npt is that you can tap your own threads easily.
Dig around on Surplus Center I get most of my hydraulics from them.
Old 07-25-2014, 05:12 PM
Kirbys73F100's Avatar
Kirbys73F100 Kirbys73F100 is offline
Kirbys73F100 is gaining momentum as a positive member of FTE.
Call Mike Ward. 205 233 1802 He'll hook you up.
Old 07-31-2014, 11:13 AM
You're gonna want to do a Saginaw power steering pump swap because the plastic ford truck pumps wont hold up. Also, check out my Rockwell build thread for part numbers. You'll need a special adapter to fit the pump.
Old 08-21-2014, 01:22 PM
Boy if I were considering a pump swap as well I'd just ditch the whole thing and go to a high pressure system using an industrial hydraulic pump on an open center system. Pure ram and orbital is all going to be rated to it (2000psi+) anyway, but the force will be roughly double with a real hydraulic pump.
Hydro Assist Steering Question Highboy74 1973 - 1979 F-100 & Larger F-Series Trucks 0 10-05-2016 10:58 PM
Steering box/brake question sleek122 1999 - 2003 7.3L Power Stroke Diesel 7 04-09-2016 01:51 AM
4x4x2 steering box. Hydro assist. rollinblackcloud Offroad & 4x4 10 03-11-2014 12:59 AM
Need exploded view of 2wd steering box 73 ford guy 1973 - 1979 F-100 & Larger F-Series Trucks 7 05-05-2009 03:09 PM
taping ford power steering box for hydro assist 78fordf150ranger Offroad & 4x4 6 10-11-2006 04:26 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
