Does anyone know the specs?
1993 specs:
For footnotes, refer to following.
NOTES:
(1) -- A/C on.
(2) -- Clutch pedal depressed.
(3) -- Steering wheel turned.
(4) -- Monitor in DCV Manual Mode, Reference Pin to PWR GND (40/60).
(5) -- HO2S should switch from rich (red LED) to lean (green LED), or lean to rich, at least once every 3 seconds. HO2S voltage should toggle above and below .450 DCV and should never be a negative value.
Reference values shown may vary ± 20% depending on operating conditions and other factors. RPM values are axle and tire dependent.
NOTES:
(1) -- A/C on.
Thanks guys, I'm also trying to figure out wheel specs since it is stock, i.e wheel and tire size, and wiring if someone can find them and link it. Wanting to make sure I can get everything I can know of my truck, so I'm trying to do alot of background info. Thanks for everything you can find in advance.
