It`s ALIVE!!!
69 C90E block .030 ARP main studs and Melling hv pump/ teflon wet gears
Eagle steel crank, 3.75-rods 6.250- Probe forged/ dished pistons 19.3
Comp Cams 35-24-8 hyd roller, Roll Master chain/gear, Howards link bars
Pro Comp heads 190 CC 60 CC chambers
Comp Cams 1.7 rollers
Edelbrock Airgap dual plane/ Barry Grant speed demon 650 vac
I like how it turned out. Thanks
I hope to have around 300 to 350 hp at the wheels and 400+ ft lbs of torque. I will have to see about a dyno locally. Not sure what that would run cost wise.
A chassis dyno should only be about $75-100 but it differs everywhere. The dyno can also tell you if you're running lean, rich, missing, or what have you.
Here you go Mike. I am running 1:7 ratio rockers both intake & exhaust. If you need more data let me know. Thanks
<table id="yiv2000783096bodyDrftID" class="yiv2000783096" cellpadding="0" cellspacing="0" border="0"><tbody id="yui_3_16_0_1_1404350366211_11851"><tr id="yui_3_16_0_1_1404350366211_11850"><td class="yui_3_16_0_1_1404350366211_11836" id="yiv2000783096drftMsgContent" style="font:inherit;"> <table id="yui_3_16_0_1_1404350366211_11849" style="border-style:double;" cellpadding="3" cellspacing="0" align="center" border="2" width="500"><tbody id="yui_3_16_0_1_1404350366211_11848"><tr><td colspan="2" align="center" bgcolor="#ffffff" width="250">ENTER YOUR DATA</td><td colspan="2" align="center" bgcolor="#ffffff" width="275">CALCULATED DATA</td></tr><tr><td align="left" bgcolor="#cccccc" width="198">Cylinder Head Volume (cc)</td><td align="center" bgcolor="#cccccc" width="66"><input name="CHV_CC" size="5" value="60" type="text"></td><td align="left" bgcolor="#eeeeee" width="189">Cylinder Head Vol
(cubic in.)</td> <td align="center" bgcolor="#eeeeee" width="124">03.660</td></tr><tr><td align="left" bgcolor="#cccccc" width="198">Piston Head Volume (cc)</td><td align="center" bgcolor="#cccccc" width="66"><input name="PHV_CC" size="5" value="19.3" type="text"></td><td align="left" bgcolor="#eeeeee" width="189">Piston Head Vol
(cubic in.)</td><td align="center" bgcolor="#eeeeee" width="124">01.177</td></tr><tr><td align="left" bgcolor="#cccccc" width="198">Gasket Thickness (in.)</td><td align="center" bgcolor="#cccccc" width="66"><input name="G_Thickness" size="5" value=".0555" type="text"></td><td align="left" bgcolor="#eeeeee" width="189">Swept Volume
(cubic in.)</td><td align="center" bgcolor="#eeeeee" width="124">47.833</td></tr><tr><td align="left" bgcolor="#cccccc" width="198">Gasket Bore (in.)</td><td align="center" bgcolor="#cccccc" width="66"><input name="G_Bore" size="5" value="4.125" type="text"></td><td align="left" bgcolor="#eeeeee" width="189">T.D.C. Volume
(cubic in.)</td><td align="center" bgcolor="#eeeeee" width="124">05.362</td></tr><tr><td align="left" bgcolor="#cccccc" width="198">Cylinder Bore Diameter (in.)</td><td align="center" bgcolor="#cccccc" width="66"><input name="CB_Diam" size="5" value="4.030" type="text"></td><td align="left" bgcolor="#eeeeee" width="189">Gasket Volume
(cubic in.)</td><td align="center" bgcolor="#eeeeee" width="124">00.742</td></tr><tr id="yui_3_16_0_1_1404350366211_11913"><td align="left" bgcolor="#cccccc" width="198">Deck Clearance (in.)
Note: Neg. nubmer above deck, Pos. number below deck</td><td align="center" bgcolor="#cccccc" width="66"><input name="DC" size="5" value="-.0170" type="text"></td><td id="yui_3_16_0_1_1404350366211_11912" align="left" bgcolor="#eeeeee" width="189">Deck Volume
(cubic in.)</td><td align="center" bgcolor="#eeeeee" width="124">-0.217�</td></tr><tr id="yui_3_16_0_1_1404350366211_11847"><td align="left" bgcolor="#cccccc" valign="top" width="198">Stroke (in.)</td><td align="center" bgcolor="#cccccc" valign="top" width="66"><input name="Stroke" size="5" value="3.75" type="text"></td><td id="yui_3_16_0_1_1404350366211_11910" align="left" bgcolor="#eeeeee" valign="top" width="189">STATIC COMPRESSION RATIO</td><td id="yui_3_16_0_1_1404350366211_11846" align="center" bgcolor="#eeeeee" valign="top" width="124">09.921</td> </tr> <tr id="yui_3_16_0_1_1404350366211_11908"><td id="yui_3_16_0_1_1404350366211_11907" colspan="4" align="center" bgcolor="#ffffff">
OPTIONAL DATA</td> </tr> <tr id="yui_3_16_0_1_1404350366211_11905"><td align="left" bgcolor="#cccccc" width="198">Rod Length (in.)</td><td align="center" bgcolor="#cccccc" width="66"><input name="Rod_Length" size="5" value="6.250" type="text"></td><td align="left" bgcolor="#eeeeee" width="161">Adjusted Stroke (in.)</td><td id="yui_3_16_0_1_1404350366211_11904" align="left" bgcolor="#eeeeee" width="160"><center id="yui_3_16_0_1_1404350366211_11901"> 02.510 </center></td></tr><tr id="yui_3_16_0_1_1404350366211_11895"><td align="left" bgcolor="#cccccc" width="198">Intake Closing Point (degrees)
ABDC @ 0.050 lift plus 15 degrees</td><td align="center" bgcolor="#cccccc" width="66"><input name="ICP" size="5" value="79" type="text"> </td> <td align="left" bgcolor="#eeeeee" width="161">DYNAMIC EFFECTIVE COMPRESSION RATIO</td> <td id="yui_3_16_0_1_1404350366211_11894" align="left" bgcolor="#eeeeee" width="160"> 06.971 </td></tr></tbody></table> <table class="yiv2000783096tborder" id="yiv2000783096post377130" cellpadding="6" cellspacing="1" align="center" border="0" width="100%"><tbody id="yui_3_16_0_1_1404350366211_11864"><tr id="yui_3_16_0_1_1404350366211_11885"><td id="yui_3_16_0_1_1404350366211_11884" class="yiv2000783096thead"> #11
1 Week Ago
</td> </tr> <tr id="yui_3_16_0_1_1404350366211_11863"><td id="yui_3_16_0_1_1404350366211_11862" class="yiv2000783096alt2" style="padding:0px;"> <table id="yui_3_16_0_1_1404350366211_11861" cellpadding="0" cellspacing="6" border="0" width="100%"><tbody id="yui_3_16_0_1_1404350366211_11860"><tr id="yui_3_16_0_1_1404350366211_11859"><td nowrap="nowrap"> dbiscayne
Registered User
</td><td id="yui_3_16_0_1_1404350366211_11858" width="100%">
</td></tr></tbody></table></td></tr></tbody></table>
</td></tr></tbody></table>Here are the cam specs
<!--[if !mso]> <style> v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} </style> <![endif]--> "> .0pt"> <table class="MsoNormalTable" style="width:7.5in; mso-cellspacing:1.5pt;mso-padding-alt:0in 0in 0in 0in" cellpadding="0" border="0" width="720"> <tbody><tr style="mso-yfti-irow:0;mso-yfti-firstrow:yes"> <td style="width:.1in;padding:0in 0in 0in 0in" width="10"> Description
</td> <td style="width:.1in;padding:0in 0in 0in 0in" width="10">
</td> <td colspan="2" style="width:.1in;padding:0in 0in 0in 0in" width="10">
</td> <td colspan="3" rowspan="3" style="width:.1in;padding:0in 0in 0in 0in" width="10">
[IMG]file:///C:\DOCUME~1\Owner\LOCALS~1\Temp\msohtml1\01\clip_i mage001.gif[/IMG]
</td> </tr> <tr style="mso-yfti-irow:1"> <td style="width:.1in;padding:0in 0in 0in 0in" width="10"> Part Number:
</td> <td style="width:.1in;padding:0in 0in 0in 0in" width="10"> <input value="35-424-8" type="text">
</td> <td style="width:.1in;padding:0in 0in 0in 0in" width="10"> Grind Number:
</td> <td colspan="2" style="width:.1in;padding:0in 0in 0in 0in" width="10"> <input value="XR276RF-HR" type="text">
</td> </tr> <tr style="mso-yfti-irow:2"> <td style="width:.1in;padding:0in 0in 0in 0in" width="10"> Lifter Type:
</td> <td style="width:.1in;padding:0in 0in 0in 0in" width="10"> <textarea rows="2" cols="20">Hydraulic Roller Lifter</textarea>
</td> <td style="width:.1in;padding:0in 0in 0in 0in" width="10"> Engine Family:
</td> <td colspan="2" style="width:.1in;padding:0in 0in 0in 0in" width="10"> <textarea rows="2" cols="20">Ford 351W 8 cyl. 1969-1995</textarea>
</td> </tr> <tr style="mso-yfti-irow:3"> <td style="width:.1in;padding:0in 0in 0in 0in" width="10"> Description:
</td> <td colspan="7" style="width:.1in;padding:0in 0in 0in 0in" width="10"> <textarea rows="2" cols="20">Hydraulic Roller-Strong mid-range performance, Street Machines with 3.55+ gears, 2200+ converter</textarea>
</td> </tr> <tr style="mso-yfti-irow:4"> <td style="width:.1in;padding:0in 0in 0in 0in" width="10"> Cam Family:
</td> <td colspan="7" style="width:.1in;padding:0in 0in 0in 0in" width="10"> <textarea rows="2" cols="20">Xtreme Energy™ Retro-Fit, Hydraulic Roller Camshafts, For engines that DID NOT come from the factory with hydraulic roller cams, NOT FOR E.F.I.</textarea>
</td> </tr> <tr style="mso-yfti-irow:5;height:14.25pt"> <td style="width:.1in;padding:0in 0in 0in 0in;height:14.25pt" width="10"> Specifications
</td> <td style="width:.1in;padding:0in 0in 0in 0in;height:14.25pt" width="10">
</td> <td colspan="2" style="width:.1in;padding:0in 0in 0in 0in;height:14.25pt" width="10">
</td> <td colspan="2" style="width:.1in;padding:0in 0in 0in 0in; height:14.25pt" valign="bottom" width="10">Intake
</td> <td colspan="2" style="width:.1in;padding:0in 0in 0in 0in; height:14.25pt" valign="bottom" width="10">Exhaust
</td> </tr> <tr style="mso-yfti-irow:6"> <td style="width:.1in;padding:0in 0in 0in 0in" width="10"> RPM-Range:
</td> <td style="width:.1in;padding:0in 0in 0in 0in" width="10"> <input value="1800 to 5800" type="text">
</td> <td colspan="2" style="width:.1in;padding:0in 0in 0in 0in" width="10"> Valve Lash:
</td> <td colspan="2" style="width:.1in;padding:0in 0in 0in 0in" width="10"><input value="Hyd." type="text">
</td> </tr> <tr style="mso-yfti-irow:7;height:16.5pt"> <td style="width:.1in;padding:0in 0in 0in 0in;height:16.5pt" width="10"> Valve Timing:
</td> <td style="width:.1in;padding:0in 0in 0in 0in;height:16.5pt" width="10"> <input value="0.006" type="text">
</td> <td colspan="2" style="width:.1in;padding:0in 0in 0in 0in;height:16.5pt" width="10"> Duration:
</td> <td colspan="2" style="width:.1in;padding:0in 0in 0in 0in;height:16.5pt" width="10"><input value="276" type="text">
</td> <td colspan="2" style="width:.1in;padding:0in 0in 0in 0in;height:16.5pt" width="10"><input value="282" type="text">
</td> </tr> <tr style="mso-yfti-irow:8"> <td style="width:.1in;padding:0in 0in 0in 0in" width="10"> Lobe-Center Angle:
</td> <td style="width:.1in;padding:0in 0in 0in 0in" width="10"> <input value="110" type="text">
</td> <td colspan="2" style="width:.1in;padding:0in 0in 0in 0in" width="10"> Duration @ .050" Lift:
</td> <td colspan="2" style="width:.1in;padding:0in 0in 0in 0in" width="10"><input value="224" type="text">
</td> <td colspan="2" style="width:.1in;padding:0in 0in 0in 0in" width="10"><input value="230" type="text">
</td> </tr> <tr style="mso-yfti-irow<td style="width:.1in;padding:0in 0in 0in 0in" width="10"> Intake Centerline:
</td> <td style="width:.1in;padding:0in 0in 0in 0in" width="10"> <input value="106" type="text">
</td> <td colspan="2" style="width:.1in;padding:0in 0in 0in 0in" width="10"> Valve Lift:
</td> <td colspan="2" style="width:.1in;padding:0in 0in 0in 0in" width="10"><input value="0.513" type="text">
</td> </tr> <tr style="mso-yfti-irow:10;height<td style="width:.1in;padding:0in 0in 0in 0in;height.0pt" width="10">
</td> <td style="width:.1in;padding:0in 0in 0in 0in;height.0pt" width="10">
</td> <td colspan="2" style="width:.1in;padding:0in 0in 0in 0in;height.0pt" width="10"> Lobe Lift:
</td> <td colspan="2" style="width:.1in;padding:0in 0in 0in 0in;height.0pt" width="10"><input value="0.321" type="text">
</td> </tr> <tr style="mso-yfti-irow:11;height:15.75pt"> <td colspan="2" rowspan="4" style="width:.1in;background: lightgrey;padding:0in 0in 0in 0in;height:15.75pt" valign="top" width="10">Installation Notes
<textarea rows="2" cols="20">[7] Stock springs cannot be used. [3]5 Part #4504 studs required for ‘78-present. [56] If equipped with studs and guide plates use part #1442-16. [1] Requires screw-in studs & guide plates. [32] Requires Lifter installation kit #31-1000 for retro fit applications. [2] Requires machining on cylinder heads. [3] Valve spring oil shield available. </textarea>
</td> <td style="width:.1in;padding:0in 0in 0in 0in;height:15.75pt" width="10">
</td> <td style="padding:0in 0in 0in 0in;height:15.75pt">
</td> <td style="width:59.25pt;padding:0in 0in 0in 0in;height:15.75pt" width="79">
</td> <td style="width:56.25pt;padding:0in 0in 0in 0in;height:15.75pt" width="75">
</td> </tr> <tr style="mso-yfti-irow:12"> <td colspan="2" style="width:.1in;padding:0in 0in 0in 0in" width="10"> Valve Timing @ 0.006" Lift:
</td> <td colspan="2" style="width:.1in;padding:0in 0in 0in 0in" valign="bottom" width="10">Open
</td> <td colspan="2" style="width:.1in;padding:0in 0in 0in 0in" valign="bottom" width="10">Close
</td> </tr> <tr style="mso-yfti-irow:13"> <td style="width:.1in;padding:0in 0in 0in 0in" width="10">
</td> <td rowspan="2" style="width:.1in;padding:0in 0in 0in 0in" width="10">Intake
Exhaust
</td> <td colspan="4" rowspan="2" style="width:.1in;background: lightgrey;padding:0in 0in 0in 0in" valign="top" width="10">
<table class="MsoNormalTable" style="mso-cellspacing: 1.5pt" cellpadding="0" border="0"> <tbody><tr style="mso-yfti-irow:0;mso-yfti-firstrow:yes"> <td style="width:75.0pt;padding:.75pt .75pt .75pt .75pt" width="100"> <input value="32" type="text">
</td> <td style="width:75.0pt;padding:.75pt .75pt .75pt .75pt" width="100"> BTDC
</td> <td style="width:75.0pt;padding:.75pt .75pt .75pt .75pt" width="100"> <input value="64" type="text">
</td> <td style="width:75.0pt;padding:.75pt .75pt .75pt .75pt" width="100"> ABDC
</td> <td style="border:none" width="0">
</td> </tr> <tr style="mso-yfti-irow:1;height:14.25pt"> <td colspan="4" rowspan="2" style="padding:.75pt .75pt .75pt .75pt;height:14.25pt">
</td> <td style="height:14.25pt;border:none" height="19" width="0">
</td> </tr> <tr style="mso-yfti-irow:2;height:14.25pt"> <td style="height:14.25pt;border:none" height="19" width="0">
</td> </tr> <tr style="mso-yfti-irow:3;mso-yfti-lastrow:yes"> <td style="width:75.0pt;padding:.75pt .75pt .75pt .75pt" width="100"> <input value="75" type="text">
</td> <td style="width:75.0pt;padding:.75pt .75pt .75pt .75pt" width="100"> BBDC
</td> <td style="width:75.0pt;padding:.75pt .75pt .75pt .75pt" width="100"> <input value="27" type="text">
</td> <td style="width:75.0pt;padding:.75pt .75pt .75pt .75pt" width="100"> ATDC
</td> </tr> </tbody></table>
</td> </tr> <tr style="mso-yfti-irow:14;height:63.75pt"> <td style="width:.1in;padding:0in 0in 0in 0in;height:63.75pt" width="10">
</td> </tr> <tr style="mso-yfti-irow:15;mso-yfti-lastrow:yes;height:19.5pt"> <td colspan="4" style="width:.1in;padding:0in 0in 0in 0in;height:19.5pt" width="10"> Recommended Components
</td> <td style="padding:0in 0in 0in 0in;height:19.5pt">
</td> <td style="width:59.25pt;padding:0in 0in 0in 0in;height:19.5pt" width="79">
</td> <td style="width:.1in;padding:0in 0in 0in 0in;height:19.5pt" width="10">
</td> <td style="width:56.25pt;padding:0in 0in 0in 0in;height:19.5pt" width="75">
</td> </tr> </tbody></table> <!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if !mso]><object classid="clsid:38481807-CA0E-42D2-BF39-B33AF135CC4D" id=ieooui></object> <style> st1\:*{behavior:url(#ieooui) } </style> <![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]-->
1 Week Ago
Registered User
Exhaust
