stock front bumper height
Right click on the picture, select save image as from the drop down menu and save it someplace on your computer where you can find it (change the name of the file to something easy for you to find/recognize at the same time like "F1 dimensions.jpg") and save it. Now find the file where you saved it and double click on it to open it in your picture viewer where you can enlarge it as much as needed to easily read it and or print it out and use a magnifying glass.
I'm assuming that one means fully loaded and the other empty? The problem is what are the measurements?
The other problem is that those measurements are to the top of the frame rail behind the rear axle . . . which is probably a better place to measure ride height anyhow.
I believe that the problem is that he doesn't know what FH & CH mean?
I don't know what they mean, but I think it's showing a 4.28" difference between FH and CH loaded and empty for the front.
The rear shows LH and EH which I would think are Loaded and Empty Heights and shows a 7.7" difference at the rear and a 7.52" difference behind the front axle when loaded..
I know that probably doesn't make sense either but ...
I'm not sure that you can compare the two charts even though logic dictates that you should be able to do so. OEMs never use bumper height as a measure of ride height. Too much variation.
