find the knock help needed
i have a knock/ leak. the front pass side of the engine you can hear a knock ( my buddy says its a air leak). yesterday when i cracked the front pass injector the engine did not change, tonite i put a new injector in and now the noise goes away a good bit. as for the part im confused about, my buddy swears its the headgasket coming out in the front of the engine, but i have not seen any other signs like oil and coolant mixing, or a loss of power.
long story short im finally stumped any suggestions?
Could be a bad valve or similar. Id pull the valve cover. Also, with the engine cool, start it and let it idle a sec. Feel the exhaust manifold right at the exhaust port, see if the suspect cylinder doesnt get hot, or as hot as the others. Works pretty good on gassers, but our exhuast might not be hot enough at idle to tell.
i cracked a few just to test, they make it miss when cracked just like a good injector should, i have a spare set laying around i think i will test and replace all of them, its been on my list for a while
they are junk no name reman injectors, so i have a set of E code stanydnes to put in
Visseroth
31
07-27-2011 12:54 AM
flatbedstroker
13
04-15-2009 07:40 AM
