Ford F600 Wiper Arm & Pivot Shaft - Ford Truck Enthusiasts Forums
Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Old 07-01-2014, 06:46 PM
BADDBOYY21 BADDBOYY21 is offline
BADDBOYY21 is starting off with a positive reputation.
I was installing a new wiper motor in my 1986 Ford F600 today. When taking the old motor out I could not get the bolt loose on the shaft of the motor. I had to take the linkage arms off so I could get the motor out and remove the bolt. When doing that I damage one of the bushings on the motor side of the arm.
My question is, can you replace that bushing or does the whole arm have to be replaced? No local parts store had any info on that bushing. I think I have located the correct part numbers for the complete arms. E0TZ-17566-A and E0TZ-17567-A. NOS Parts LTD. wants $80 a piece plus shipping. Does any one know where I can find them cheaper?
Any advice on how to install the arms back on to the motor shaft without damaging the new bushings?
Thanks,
Shawn
Old 07-06-2014, 09:20 PM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
My question is, can you replace that bushing (no) or does the whole arm have to be replaced? Yes.
The correct part numbers for the Arm & Pivot Shaft Assy: E0TZ-17566-A Right ~ E0TZ-17567-A Left / Obsolete
1980/86 F100/900 & Bronco / 1987 F150/900 & Bronco before production date 6/87.
When the 2nd digit of the part numbers prefix is a zero, it can also be typed as the letter O.
EOTZ-17566-A =
BOWMAN SALES & SERVICE in Bowman ND has 1 = 701-523-3257.
WESLEY OBSOLETE PARTS in Liberty KY has 1 = 606-787-5293.
NOS PARTS LTD in Waxahachie TX has 1 = 972-937-2201 (as E0TZ).
EOTZ-17567-A =
GREEN SALES CO. in Cincinnati OH has 1 = 800-543-4959.
MILLER OBSOLETE PARTS in Binghamton NY has 1 = 607-722-5371. (as E0TZ).
DON SANDERSON FORD in Glendale AZ has 2 = 623-842-8643.
NOS PARTS LTD has 3 (as E0TZ).
Radius Arm Bushing Job Coastal68 1967 - 1972 F-100 & Larger F-Series Trucks 4 03-27-2016 05:30 PM
Need part number for shifter arm bushings ericknight 1967 - 1972 F-100 & Larger F-Series Trucks 18 05-22-2015 08:59 PM
92 F150 4X4 won't start w/ clutch in and hard to shift milehieagle 1987 - 1996 F150 & Larger F-Series Trucks 1 01-01-2015 10:05 AM
Radius arm bushing temporary fix Derrick lane 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 12 12-12-2010 07:29 PM
Electric Wiper Conversion on my 51 doug51f1 1948 - 1956 F1, F100 & Larger F-Series Trucks 11 09-13-2008 12:15 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
