F700 GVCW ?? - Ford Truck Enthusiasts Forums
Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
F700 GVCW ??
Old 07-01-2014, 05:03 PM
challenger2k challenger2k is offline
challenger2k is starting off with a positive reputation.
F700 GVCW ??
Does anyone know the gross vehicle combination weight rating (GVCW) of a '92 F700 dump, (429 gas automatic trans).
Should I be able to tow a 6K trailer loaded with a Case 580SL (18k lbs), or a Komatsu PC100, (24k lbs)? It feels a little weak, with poor accel., especially on a light grade.
What kind of gas milage should I get. empty vs loaded?
Old 07-02-2014, 03:04 AM
1969furd 1969furd is offline
1969furd is starting off with a positive reputation.
gas milage 4-5 MPG loaded ford big blocks (460's) only got 10-12 in a 1 ton truck so you might get 8 empty
Old 07-02-2014, 08:54 AM
gandrimp gandrimp is offline
gandrimp is gaining momentum as a positive member of FTE.
I'm not sure a trailer that only weighs 6k will safely haul 18k much less 24k.
My trailer weighs 7.5k and is only rated 20k, that said, I have had 24k on it but I was left wanting more brakes.
Old 07-03-2014, 12:15 PM
Holden 10 ton trailer (Ameritech)
Thanks for the feedback guys. The backhoe should be fine.
Darn, I just finished restoring the trailer before I got the excavator, it's a Komatsu PC100-6, 23,500 lbs.
I can't find the GVCWR for a '92 F700 anywhere. I want to be around 50K lbs. Things get costly above 54k.
I hope I don't have to invest in another truck and trailer. This 5-6 yard truck is perfect for residential work, and the trailer was just restored, oh well.
Thanks again for your help,
Old 07-04-2014, 12:04 PM
dmanlyr dmanlyr is offline
dmanlyr has a great reputation on FTE.dmanlyr has a great reputation on FTE.dmanlyr has a great reputation on FTE.dmanlyr has a great reputation on FTE.dmanlyr has a great reputation on FTE.
The GCWR is easy to find, at least the maximum properly equipped, it is listed in the sales brochure. You are most likely looking at a MAXIMUM of 42k as a GCWR, that is the standard on F700 thru at least the 60's to 70's.
It is also listed in some of the owners manuals.
David
Towing with the V-10 bryanw47 Modular V10 (6.8l) 6 04-10-2016 10:07 PM
Gooseneck Towing with 5.4? jh225 1999 to 2016 Super Duty 9 06-09-2012 12:38 PM
GVCW - towing capacity 1987 F-350 7.3L diesel nebula aluben Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 2 02-10-2011 07:38 PM
GVCW - towing capacity 1987 F-350 diesel nebula aluben 1987 - 1996 F150 & Larger F-Series Trucks 1 02-10-2011 01:48 PM
97 F350 GVCW ticket for overweight millerandsonbobcat Flatbed, Car, Boat, Utility, Horse & Misc. Trailer Towing 12 04-02-2010 12:27 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
