92 F350, 460, C6, 36" Tires, What Gears?
Looking for some input from people with a similar truck or situation. We bought the truck a few years ago and have been rebuilding it since. Step by step we have taken this thing from a beater mud truck to where it sits today.
Motor has plenty of power but I think the bigger tires are affecting our off road and towing abilities. It has stock 3.55 gears, dana 60 up front and sterling 10.25 in the rear. We drive the truck in the summer for towing our camper, and heading up to the sand dunes. We drive it between 2-5 thousand miles a year due to our jobs and the weather here in Michigan. Truck is not abused off road but we want to be able to get the power to the ground. When towing we keep it right around 60-65 mph, on the dunes we barely go above 30.
I want to find the hill climbing power I know this truck has, but I think the gears are holding us back. Wondering what gear set would get us up all the dunes and be great for towing. 4.56 or 4.88 or?
The C6 doesn't have an overdrive or a lockup torque converter, so you don't want to go too low with your axle gears or your mileage will plummet and it'll be less pleasant to drive on the highway due to engine noise.
That said, you're pretty tall now. 3.55 gears at 60 mph put you at 1930 rpm (higher really due to no lockup torque converter). That's not too bad for mileage, but it does mean you'll need to downshift to get up hills with a load.
4.10 gears would put you at 2300 rpm at 60 mph. Probably a good place to be if highway driving was your only concern.
4.56 gears would put you at 2480 rpm and 4.88 gears would be 2660 rpm. Getting pretty "buzzy" at those speeds, especially if you want to go faster (70 mph would be 2900 and 3100 rpm, respectively).
But you also want to be able to drive dunes in 4WD at 30 mph. I'm not sure what your transfer case low range is (you do use low range, right?), but it's probably pretty close to 2.6:1. I'm also not sure what gear you wasnt to use on the dunes, or what the C6 ratios are in 1st or 2nd.
But assuming you want to be in 3rd gear at 30 mph in low range (and assuming 2.6 t.case gears), 4.10 gears put you at 2900 rpm, 4.56 gears put you at 3230 rpm and 4.88 gears give 3457 rpm.
I haven't driven dunes ever, so I can't give recommendations there, so I'll just leave it with that data.
Received 3,106 Likes
on
MUSKRATT2
05-02-2011 08:40 AM
Sycostang67
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
09-27-2004 10:12 PM
